Boomzbox Sleep/Hibernate issues
  • Boomzbox Sleep/Hibernate issues
    Okay so I've tried everything to make the Boomzbox resume properly after a hybrid sleep resume and hibernate resume. I can hear the clicking noise that the radio makes when Centrafuse loads back up but the radio just wont initilize. Everything appears to be working as it should but there is no sound. I can change stations and the HD signal flashes as it should when trying to lock on to the signal. I don't hear the audio cutting in and out when it first initilizes when Centrafuse loads from a cold boot. When i exit Centrafuse after resuming from hybrid sleep to load the Boomzbox HD software, the software doesn't recognize the COM port even though it's set to the correct port. I have delay on resume set to three seconds under general settings and the radio set to six seconds delay. I'm running the 3.1.3 version of the boomzbox software and all the latest drivers. I've ran the "setcorrect" script settings so I think everything is the way it should be. I have no idea what the problem could be. I'm running Windows 7 64 bit with CF3.1. The Boomzbox usb cable is plugged into the front of my mo-co-so carputer (Motherboard is a Jetway NF93). 12v power is supplied from the PSU via floppy disk connector. Everything is hooked up correctly.
    This is the error that the Boomzbox HD software gives me when it tries to locate the radio after resuming from sleep or hibernation and the radio doesn't work. I get the same error after a cold boot but the radio still works:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    MJSGAudio.MmException: MixerInvalidLine calling mixerGetLineInfo
    at MJSGAudio.Mixer.MixerLine..ctor(IntPtr mixerHandle, Int32 destinationIndex, MixerFlags mixerHandleType)
    at MJSGAudio.Wave.WaveIn.GetMixerLine()
    at HDRadioDemo.AudioCapture.NewRecord(String captureDevice)
    at HDRadioDemo.HDDemoMain.AudioStart()
    at HDRadioDemo.HDDemoMain.HDRadioCore_HdRadioEvent_Po weredOn()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    BoomzBoxHD
    Assembly Version: 1.3.1.3
    Win32 Version: 1.3.1.3
    CodeBase: file:///C:/Program%20Files%20(x86)/BoomzBox%20HD/BoomzBoxHD.exe
    System.Windows.Forms
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Design
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    carputers
    Try it with a powered USB hub plugged into a wall outlet. Stop the car, let it hibernate with Boomzbox plugged into the powered hub. Restart the car and see if it finds the Boomzbox.
    If it does, your problem is with a resume on hibernation for the USB ports rather than the Boomzbox.
    Want to:
      Novak, i think you got two different issue here
      with CF, im not sure... but what bugbyte suggests might be good
      the boomzbox HD software, has nothing to do with Centrafuse
      the error you posted, has to do with AUDIO... which is possible thie usb devices hasnt come back into system
      PLUG the boomzbox HD usb interface into a native USB port, not a HUB
      mitch
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        mitch
        It's not plugged into a hub and is plugged into the main panel on the motherboard. Could it be an onboard audio problem? I'm wondering if I should add a PCI sound card since the mo-co-so case that I use supports it. What are the benefits to using a PCI card?
        carputers
          ok, thats good...
          i dont think its a on-board audio issue
          but its acting like at the time of resume, the usb device isnt there
          when you resume...
          im not familiar with "hybrid sleep resume and hibernate resume"
          i use windows7, and i have done "regular" i guess resume... and never had any issues
          in boomzbox hd software, when it detects going into hibernation, it stops audio and shuts off radio...
          when it comes back (resume), it powers on radio , and starts audio
          the exception you got there, looks like the audio device is missing (the one internal to the boomzbox HD interface)... maybe we need a slight delay... for hardware to settle... i can add that in and you test
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            Was there a resolution to this? I am having the same issue. Boomzbox is connected directly to the motherboard via usb full shutdown reboot it works fine, but hibernate/resume it just clicks alot and can not initialize. Running a zotac nvidia atom board on win7 32bit centrafuse 3.1.
            ---Update---
            Running windows xp now since realtek win7 drivers suck. This resolved alot of audio issues. Granted xp was harder to setup and config because I needed to align my ssd and turn off certain things and boomzbox centrafuse xp issues (fix by the way is to edit the cf config.xml and change a -1 to 1 for radio input), but in the end its running much better then win7 build ever did.
            My CarPC Mitsubishi Lancer Evolution IX MR
              #1 issue with resume is wiring of the power to the radio, people seem to use ignition, the radio must have power when the pc has power... nothing wrong
              with wiring the power to constant.. the pc controls if the radio is on or off
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Boomzbox/bluesoleil bluetooth
                I have problems with the boomzbox hd after I had installed bluesoleil bluetooth. Before I had installed bluesolei, there was no problem with the boomzbox (occasionally needed to restart the pc after hibernation inorder to make it work). After I installed bluesoleil boomzbox hd had stopped working and it's not being initialized. After I uninstalled bluesoleil, it worked again. Does anyone have the same problem/know how to fix it? I am using windows 7 62bit and bluesoleil version 7.
                  since you provide no real information here...
                  after installing bluesolei, does the boomzbox HD application work?
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
