Boomzbox HD - Static problems
  • Boomzbox HD - Static problems
    Hi, I recently bought a a boomzbox HD Radio unit and everything works fine. But I am getting this small static noise (sounds like digital noise), in the back ground when the audio hits a certain frequency. It's more present in AM but it is present in FM as well. When I use the factory radio player that came with the Boomzbox, it seems to cut down on the noise but not completely. This is my set-up:
    Intel Atom D510MO
    Boomzbox HD Radio
    M2-ATX
    Win 7 Ultimate
    CF 3.1
    Note, that the noise is not always there, but only there when the actual audio hits a certain frequency (not radio frequency). It is kind of like an echo or something, it's hard to explain and I can make a recording if needed.
    Thanks,
    is it a high pitched noise? constant level
    if so...
    there is a small change you can make... pm me
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      if so...
      What solved this? I get it too, in the qweeters. Also my boomzbox program won't boot. I can run it through get the radio through centrafuse but not in windows alone. Being that I don't want to use centrafuse anymore, this is a problem.
        well.. since i never got any answers.. i cant tell you
        boomzbox sw is .net so if your running on a OLD os...like xp, make sure you have .net 2.0 framework
        but since u use centrafuse, which is also .net, my guess is its not that
        and it would give you an error...
        wont boot, is vauge, since for one it doesnt boot, it runs
        mitch
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
