Help required with Infill T3 - power up
  • Help required with Infill T3 - power up
    Hi everyone,
    I've just acquired a secondhand Infill T3 and am having trouble getting it to fire up on a Molex supply.
    I have to 'fiddle', plugging and unplugging the 2 unit's power cables and the large black connector that links the units whilst pushing the PC unit's power button. Every once in a while I get lucky and it starts - I then plug in the screen and it opens to show the normal boot screen however the hard drive is not being found. I've tried swapping with a spare 40Gb HDD and still no luck.
    Is this a problem with not enough power getting to the unit or something else?
    I notice the fan on the back of the PC unit is running when the ignition wire is connected without the unit actually being on.
    Also, I sometimes get continuous flashing LEDs on the PC unit?
    The PSU is rated at 30A on the 12v rail and is 550W but a voltage tester shows 11.44volts.
    Unfortunately I don't have any instructions apart from a wiring install I found on the 'net.
    Any help would be very welcome!!
    Thanks,
    David
    Ok, have now got the T3 to power up... sometimes!
    I've found 2 of the FFC cables (very thin ribbons) to be damaged.
    One was an IDE connector - now have HDD but no optical drive.
    The other is the connector cable from the PC unit to the front panel - this is the one causing most problems as it seems to have some control over the power up process.
    Can I by these cables as spares from anywhere??
    Please help!!
      Fixed it!
      Cannot believe I've managed to get it all up and running.
      I sourced some 0.5mm pitch 50 pin FFC cables from www.digikey.com and they arrived in the UK in 5 days.
      Bought 3 different lengths and had to modify the width (no of pin outs) for the front panel and motherboard to fixed front cable but was quite easy.
      Now have a fully working T3 and am very pleased.
        Now have sourced the cables and the machine works 100%.
        Sorted!
