Changing LEDs and Updating HDD
  • Changing LEDs and Updating HDD
    Does anyone know how difficult it would be to change out the red LEDs to Blue? I'm swapping out all of my green LEDs in my car to match the blue of the MyColor instrument cluster and would prefer not to have red in there as well. Also is updating the HDD that difficult? I haven't seen any inside pics of the unit.
    Thanks,
    -Deric
    Click for my projects
    2006 F150 with removable Nexus 7
    2006 Mustang with indash CarPC (Retired)
    Regarding LEDs - the unit is so new that I doubt that anyone has taken it apart yet to change out the LEDs. Doing so will void your warranty.
    Regarding the HDD - again, the unit is so new that I doubt that anyone has taken it apart yet to change out the HDD. Doing so will void your warranty.
    Jan Bennett
      Updating the HDD is more time consuming then difficult, but there are some ribbon cables that are somewhat sensitive to tearing. If you've completely taken apart a laptop before, the G4 should be similar.
      The LEDs are square and have 4 contact points each and are 4 mm wide. I haven't tried replacing them. They are on a seperate circuit board also containing the buttons and IR sensor. Don't take this as an endorsment or a recognition of this as covered under the warranty in any way, but they look no more difficult to replace then the circuit board mounted LEDs in my car and would say it is possible to successfully do, but still can't confirm it. If you do attempt this, I would be very careful when soldering around the IR sensor as it is probably sensitive to heat.
      StreetDeck.com Developer (I am Chuck)
      Get StreetDeck at http://www.streetdeck.com
      The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
        hi, here you can see how to replace the dvd reader and the hd.
        this document is from www.cartft.com
        http://www.cartft.com/support/doku/m...ill_G4_ENG.pdf
          Nice! Looks pretty simple I was afraid that the guts of the G4 would be a mess but the layout seems pretty clean. Much better then the innards of the MacBooks and Ibooks I'm used to seeing.
          -beef
            ...which makes me wonder why would a simple LED have 4 contact points? Is there any chance of them being multi-color LEDs? If so, there must be some easy way of powering different contacts to get different colors?
              They are not multicolor leds.
                -beef
                Looks far more easier than upgrading the T3 harddisk and memory. I'd say the T3 is a 8 out of 10 on the difficulty scale..
                The T4 is a 6 for HDD and 7 for memory at that
                  that doesnt seem too hard even for a noob like me... but im still sota concerned. Will doing this void warrenty of the unit? Is it possible to get the unit "empty" or with any HDD or dvd drive of my choice?
                  J. J
                  http://www.cardomain.com/ride/2604492
                  TYPE RF System INSTALLED:
                  RAVDVD1, Front: Silk FNX/FNQ 6.5, Highs amp: 801X
                  Working on:
                  Midbass: 8 HX2, Center: 4 FNQ, Midbass Amp: 801s, Center Amp: 301m, Sub Amp: T30001bd, Processors: 2 3Sixty.2
                    I'd wait to see the store once we recieve the next batch.
                    You will not be able to select the CD drive for sure, however, we're looking into HDD and memory options.
                    Jan Bennett
                      ok thanks... any chance you can comment on the thread i posted up? Reason why i asked about changing is because im not sure about dual layered dvd's and different burning capabilities
                      J. J
                      Working on:
                        sry forgot to ask any idea when the next batch is to be avail in the store?
                        J. J
                        Working on:
                          I'm not privy to that information unfortunately.
                          Jan Bennett
                            We had a batch that came in and they have all been spoken for. They should ship on Thursday. We highly encourage you to put one on order. We don't bill your card until it ships, but this gets your name on this list so you are first to get one when the next batch comes in.
                              I called the other day to order one and they said i had to do it online, but had to wait until they were in stock to do so. How can I be placed on the list?
                              _______________________________________________
                              All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
