Infill G4 inside - does PCI slot exist and empty?
  • Infill G4 inside - does PCI slot exist and empty?
    Hello all.
    I wish to buy Infill G4, and thinking about removing the amplifier from it (will use more powerful external amplifier) and install my PCI sound card (SB0610). But I dont find any photos of the inside of the G4 and dont know does PCI slot exist and empty? Will thanks for information.
    PS: Sorry for my english.
    There is not an internal PCI slot even avaliable in the G4.
    Jan Bennett
      It is a pity...
        I don't know the link from memory, but there are several photos around the forums of the inside of the G4 including "how tos" [e.g. swap out this or that]. Search and ye shall find...
        _______________________________________________
        All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
          I tried search few hours but found nothing. Can anyone give me a link?
            I couldn't quickly find the post that had the link, but here was a .pdf I grabbed from another site.
              Very thanks. It is better than nothing.
              In this pdf I dont seen the amplifier - maybe it is located at the bottom of the case, below the motherboard?..
              PCI slot seem truly not exist. But on the page 6 it seem two unused connectors are present. At the right bottom corner of the metal star . I cant identify this connectors, which type they are?
                tried to add image by editing - not success, posting by another post
                hmm, cant attach an image, so posting link:
                http://personal.primorye.ru/speller/tmp/g4ins.jpg
                connectors covered with blue color.
                  You should be able to attach an image no problems. If anything you should be able to upload using your user images found in the UserCP drop down (at the bottom of the drop down) located at the top left hand corner of any forum page.
                  Jan Bennett
                    My question is still actual: what connectors are in blue square?
                      Without knowing what they are for, the connectors look like the one you find on the back of the DVD drive.
                        from the pictures it appears that if there are any expansion slots, then they are the smaller laptop type. if it's got anything it would be a mini-PCI or a mini-PCIe slot. either way you won't be able to use your PCI soundcard with it (unless there is some sort of adapter you could use?)
                        F150 Truckputer [1.0] (coming soon!)
                        Fusion Carputer [2.0]
                        Fusion Carputer [1.0]
                          If it is any kind of PCI(e) slot, so it would be a smaller problem to find an adapter, I think.
                            Those are ribbon cable connectors. Could be for anything from button control to display.
                            Contrary to my profile information, I am not "Streetdeck Staff" and have not been for quite a while.
