Fishing Boat Installation - Hard Drive Shock, Vibration - SSD, Flash?
  • Fishing Boat Installation - Hard Drive Shock, Vibration - SSD, Flash?
    Hello all, I have a 7" monitor hooked up to my Ibm Thinkpad that is placed onto a docking station under my center console whenever I go on a fishing trip.
    Problem is, I don't want to risk messing up my school/work computer. A bigger problem is that the motherboard/hard drives park whenever there is excessibe vibration/shock, so the GPS does not update until I slow down the boat (this is not good because I want to use if for real-time navigation). I know that this has been discussed extensively in the car domain, but there aren't any absorbers when going over rough waves or even constant vibration. I use the computer as a GPS system with Earth NC, google maps, and goops to track the boat as it is moving.
    I want to build a dedicated system with the atom motherboard/processor (intel D945GCLF), the M2 power supply, and the Ampie car case. Memory is straight forward and I don't think I will need to use the ignition control of the power supply since I will want the gps to be on even when we are not moving the boat.
    My main question is reguarding the hard drive. I would ideally like to put a low cost SSD drive so that shock and vibration is not an issue. This seems to be very expensive. Should I look into a laptop harddrive that does not have the free-fall accelerometers that park the heads during motion at the expense of possible breaking the hd, or is there a way to just install the operating system on a flash drive since I don't require much storage space for music or anything? Thanks for your help.
    Marc
    Marc
    Ignition - Even though you don't plan to use it, i would consider wiring the computer into a switch on your instrument cluster. It would be handy to be able to reset the device without getting your head buried int he computer.
    We have installed hundreds of Seagate EE25 shock resistant hard drives in boat solutions and had great success. However, these boats were not getting airborne over 4' rollers. A 40gb ee25 is about ~140 and could be worth a try. As a worst case scenario you could always buy an SSD later and use the 40gb drive as a media storage location.
    -Rob
      Update on Boat Computer
      Thanks for the information. I decided to not worry abou the hd or figuring out how to install the OS onto a flash drive and went with a 32GB SATA II SSD. It ended up being ~$170 after a $40 rebate. Pretty good price if you ask me. The OCZ Core series.
      I definitely want to have the power switch easilly accessible, so I was thinking of getting a power switch cable from an old computer case and mounting it onto the console. Are there other methods, or rather is it easy to do this with the waterproof buttons on the instrument panel? I am not sure that I have any buttons that aren't being used for the lights, live wells, etc, but I will check. Or, do you think I should get a waterproof button that will be compatible with power/reset jumpers on the mb?
      I am using the rubber "virtually indestructible keyboard" and just bought a $5 roller-ball mouse for input devices.
      As this fishing boat is used in saltwater bays, do you think I should spray the mb/electronics with corrosion X an insulator coating/oil before putting it into the case. It will be stored away underneath the center console, but I want to keep it on the boat at all times. Thanks for your response and I will try to keep you updates with my progress.
        Switch:
        If it were my boat I might be lazy and use an extra panel switch to control the accessory wire, in turn controlling the computer shut down.
        I don't know what the length limit on a MB shutdown wire is, but I would guess you would be able to get several hundred feet out of it. on most motherboards all you really need to do is 'short' the two pins.
        With that being said, the best thing to do would really be to have a water proof button that would turn the computer on and off. If the computer froze, you could always hold the button in to force a power down and restart.
        Spray:
        Without knowing the exact layout of your boat i can't provide a lot of advice here. Since this is actively cooled you might have some problems. How much this will reduce the life of the system is really a guess without more details.
          Originally posted by Fiberoptic View Post
          Switch:
          Spray:
          Are you familiar with the atom board and processor? I know it has been said to get very hot and that an upgrade to a better heatsink might be a good option. Thoughts?
          So Ampie Case and Fan with current heatsink. Can this be converted into passively cooled? Only problem is the working environment is also hot i.e. under the center consol in Galveston, TX summer. I would not want to draw in air to run it through the case, but can the case just be used to blow hot air out and not bring cold air in? I don't want salty air to be sent though the case. This may not be a big deal since it is under the console but there are some holes that let air in under there.
            Atom heat sink upgrade - I wouldn't bother with a heat sink unless it is really air tight environment. Intel is very particular about their thermal planning. The Ampie case does have some airflow problems. you can always add one later if you think your cpu is throteling back. Check the built in temprature monitor after you install is done.
            Passively cooled conversion - anything is possible with enough time. But is it really worth it? What if you just replace the board in a year or two when it fails?
              Why don't you post some pictures of your install location. Maybe some other people can chime in with ideas.
                Sounds like a good plan. Maybe I am worrying too much since only one or two applications will be running at a time. I think that I will be okay as it will be pretty shielded from the environment under the center console. And you are right. This motherboard is pretty cheap to begin with, but hopefully it will last for a while. More importantly, I hope the SSD and power supply last longer than the mother board. I have read about spraying the components to sheild them from corrosion. I think this will be fine once all of the components are in place (conducting). The corrosion-resistant sprays just act as an insulator from the environment. Should be fine.
                  I'll be able to post some pics and work on it this weekend. Thanks for the input.
                    Just to let you know what my upgrade plan is...
                    I'd wait for the second version of the Atom board to come out the D945GCLF2, supposedly in just a couple of weeks.
                    http://www.mp3car.com/vbulletin/gene...core-atom.html
                    There is a low profile heatsink upgrade available that will work on both atom boards.
                    http://www.mini-box.com/Heatsink-rep...1GLY2-D945GCLF
                    TruckPC - gutted, being used for test setup
                    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
                    BlazerPC - Nexus 7 with Timur's USBROM
                      Well, I already have the first board on it's way to my house. I am not critically concerned with computing power of the board. Not sure if the heat will be dramatically reduced with the new one, but maybe I can replace the heat sink later.
                        From another post: :Location Updates I am using goops on my boat and would also really benefit by estimating the track between gps spots. Especially since I would like to use the aerial views to estimate the shallow areas in the bay.
                        On that note, what are the optimal settings to get the update to run faster? Is this solely based on the output rate from the GPS unit? In my case, I am using a Garmin GPS/fishfinder.
                        Thanks in advance,
                        marc
                        Marc, How are using google earth in your boat? I wanted to continue the conversation from the LCD thread, but since it was off topic I thought I would move it over into the boat computer section.
                        Don't a lot of the charting software packages do what google earth does and combine it with nav and underwater charting?
                          To tell you the truth, I haven't looked into many charting software packages. Which ones have you heard of? I like using goops into google earth and have overlaid raster maps whose opacity can be changed. It is nice to have sattelite views of very shallow areas and the depths predicted by raster plots. I bought the raster charts package from earthnc, but I have found that I can make them from the same free source online. I can also modify the color-shemes of the map to give more contrast. Especially because of my LCD outdoor visibility problems as discussed in this forum:
                          http://www.mp3car.com/vbulletin/lcd-...ml#post1324592
                            It is also very easy to add placemarkers i.e. fishing hotspots, channels, etc. Overall, I just like the flexibility offered by google earth. The only thing that makes me mad is when google earth is started up on the boat, I get error messages and have to close a couple dialog boxes to accept that I am not connected to the internet. Other than that it works very well.
                            I also have an old Garmin gps/depthfinder on board that is now dedicated for depthfinding only and as a gps backup. I have used the serial cable from the Garmin (NEMA comm) to send info to the pc and also have a usp gps antenna that works very well. Having backup solutions are key.
                            I'd like to find some software application that would display the depth found on the garmin and could display it on the PC.
                              You could probably hibernate to get rid of those warning boxes.
                              Does the depth information come from a sonar reading or charts? In the past I have used some of Maptechs products. Next weekend I hope to test some mac software using a p2140 and a mac mini.
                              Are you using the Google ocean component? I would imagine the 30 meter resolution isn't enough to tell you much.
