How would you wire in an amp and subs without rca outs?
  • How would you wire in an amp and subs without rca outs?
    hey guys,
    i want to put an amp and sub in my buick but I'm planning on still using the stock radio. It doesn't have rca outs so what are my options?
    I have heard run the signal to the amp from the rear speakers (left rear speaker positive, right rear speaker negative) and then use a low pass filter or a crossover.
    Is that my best option?
    thanks!
    mikeym
    If you want to run the signal from the radio, use the wires from the front speakers. The best thing is to use a LOC - level output converter - that will give you the rca outs.
    Here is how they look like:
    PAC OEM-2
    http://sonicelectronix.com/item_4806.html
    PAC SNI-35
    http://sonicelectronix.com/item_5265.html
    Scoshe, tsunami and other make LOCs as well, it seems that the PAC is a good quality.
    Check ebay as well.
      ah, thank you very much!!! the 2nd one looks easier to use! haha.
      Can you explain how that would work? Do I splice into my front speakers?
      I still plan on running the front speakers (2 tweeters, and 2 - 6 1/2 inch components) and the rear speakers (6x9's) off the factory hu
      thanks!
      ~mikeym
