help
  • help
    im installing a car stero/mp3 deck into my 1996 Chevy S10 and the antenna wire from my truck is too small and does not fit in the plug on my pioneer deck any suggestions im thinking of just running a wire into the deck but i dont know please if you have any suggestions let me know this is my first time working with car audio
    You can buy an adaptor from circuit city or best buy to fit the antenna
      they arent close to where i live really do you think wal mart has em and can you give me a brand or place to searc for em on the internet
        Walmart has (well, mine did) a crazy octopus looking antenna adapter that should cover what you need. Its a hack way to do it though.
        The one you should use is by Scosche...
        http://www.scosche.com/scosche_carau...42&ItemID=MDAB
        2005 Ford Focus ST
          Walmart might , I would check , it cant hurt
          Here you go .GM Antenna Adapter Motorola M to OEM antenna F
          http://www.crutchfield.com/S-fcSRkw8...p.asp?g=119400
            Doesn't walmart carry a ton of Scosche products?
            1.9in x 2.9in -- 47mm x 73mm
              thanx guys
                The one local to me didnt have much of an assortment, instead offering the cheesy octopus affair. It was enough to get me going, but I replaced it with a real one after the weekend.
                2005 Ford Focus ST
                  No proplem ,thats what I'm here for
                    Ah. I guess different walmarts carry things more suited for their location. One walmart by me has an entire aisle devoted to Scosche products while another has just a little 4'x4' board with the wiring basics by the cheap HU's...
                    I am curious about this octopus thing though... Was it every possible proprietary antenna connector to a standard connector type adatper?
                      I cant find it listed on the website, but i found a pic online. Weird *** deal if you ask me, but it served its purpose. Took up a lot of room too! I know it had the end I needed for my car, not 100% on the GM connector
                      2005 Ford Focus ST
                        And that thing was probably cheaper than the single converter because it is walmart and that is what they do!
                        Interesting to say the least.
                          I guess they figure if your buying your car stereo stuff at Walmart, you deserve this kind of quality
                          2005 Ford Focus ST
                            IF I saw that thing on the ground I would stomp on it and hope it didn't bite me first!!
                            TO the OP, I'm glad you got you problem solved, but if you post more could you please use descriptive thread titles? Help! Doesn't tell us anything about your problem and makes every one either read the post when they may not be able to contribute OR ignore it even though they may be able to.
                            Its not the cards you're dealt, its how you play the hand!
                            Originally posted by ryuandwings
                            Where can I get a roll of tin foil?
                            I been looking for that all over the net, but I can't find it.
                            Please help.
