2 Amps to Headphone Jack?
  • 2 Amps to Headphone Jack?
    I have an onboard soundcard and im trying to connect it to 2 amps (4channel 460W each). Do you see any problems with splitting the RCA's? Enough voltage/power? I'm a good computer technician, but when it comes to car audio I'm just a noob! Help ASAP please! Thank you
    Brasil in 2007...
    What kind of MB you using? I know with the M10000 you can set all three of the audio connections to do 5.1 so you wouldnt have to split the RCA's
    MY INSTAllS:
    http://www.mp3car.com/vbulletin/show...e-install.html
    http://www.mp3car.com/vbulletin/show...tallation.html
      the M10000...how do i set that up? Thank you for your fast reply
      Brasil in 2007...
        http://www.via.com.tw/download/mainb...IA-M_v1.40.pdf
        Give this a shot I can only spoon feed half of the way. Search is your friend! Its always good to have a manual on hand also but this should set ya up
        Aron
        New Ipad
        Zapco DSP-6SL
        Zapco Reference 360.4: H-Audio Soul, x2 right side
        Zapco Reference 360.4: H-Audio Soul, x2 left side
        Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
          There is a sticky too. "How to get 5.1 out of your via board" or something close.
          1.9in x 2.9in -- 47mm x 73mm
            Thank you very much guys, I am looking into that pdf at the moment! And so I guess what I need is to set it up as a 5.1, correct? If its not set up as a 5.1, will splitting the RCA mess things up? Scary when it comes down to burning your hardware!!
            Brasil in 2007...
              Thanks for the pdf, it was easy to understand, and I am working on my amps today still! Thank you again
              Brasil in 2007...
