2 channel amp 4 speakers? Possible?
  • 2 channel amp 4 speakers? Possible?
    Haha well I just upgraded my front components powered by a kickerzx200.2 and now I want upgraded rears, (bad timing i know) is it possible to just run aftermarket speakers(2) and plug them into each channel? and still maintain decent sound overall? i know i should just buy a 4 channel amp but im cheap haha thanks
    You could attach the rear speakers to the amp in series with your front (Front right/positive and back right/positive connected to the right/positive terminal on the amp, front right/negative connected and back right/negative conntcted to right/negative terminal on amp, ect.). But with this you wont have the feature of fading between the front and back speakers. For more help just search for wireing diagrams on the internet.
      You can only do that safely if the amp is 2ohm stable...
      Do you have a powered headunit? Like an amplified head unit that says 35x4 or somthing? IF so, run your rears off that. Its about perfect for rear fill anyway. You don't want to give your rears = power as your fronts for optimum sound anyway. SOme people swear rear speakers are the devil. I like them, always thought they give best imaging and staging. But I underpower them compared to the main stage.
      Its not the cards you're dealt, its how you play the hand!
      Originally posted by ryuandwings
      Where can I get a roll of tin foil?
      I been looking for that all over the net, but I can't find it.
      Please help.
        well my amp is 2 ohm stable, Mike if i wired it like the way u say can u explain to me what ohms i would be running and how much my 200 watts would be split between 4 speakers? Thanks alot for the help
          What impedence are your speakers? You won't know what load your amp will see until you know what the resistence of your speakers will be.
          Please help.
            Your speakers should be either 2 or 4 ohms if you wire two 2 ohm speakers in parallel it is the equivilent of 1 ohm which may be a little much for some amps so you may need to wire them in series to make it 4 ohms.
            Here is a good website that explains series and parallel wireing with speakers: Series Vs. Parallel Wiring
              oh sorry my speakers are all 4 ohm
                Well that amp is rated for 2Ohm 100w x 2ch, so the easiest thing to do is wire the rear speakers in parallel with the fronts.
                Manual for reference: http://www.kicker.uk.com/pdf/zxAmpli...0c01%20WEB.pdf
                  Yes you can do it, but the front and rear speakers might be the same model, cause if they are dif, the little one, could be damage cause it will handle less, and the power wont be equal shared.
                  Design [000000000-]90%
                  Parts [000-------]30%
                  Installation[----------]0%
                  Integration[000-------]30%
                    so i wire it like mike said?
                    with a zx200 how much power would be given to each speaker(4)? Thanks for the replies!
                      That's parallel wiring...
                      -ZtH01
                      "It's my belief that my big balls should be held every night"
                        ZtH01 is correct, xxMIKExx showed an example of parallel wiring. But, it is still what you would do in this case.
                        NightBlade, you would wire it that way, yes. According to the specs for the amp it's rated at 100w x 2 in that configuration, so in theory you would be putting up to 100w RMS to each speaker (I think that's how that works)
                          i thought i was putting 100 rms to each speaker now with 2? wiring another 2 to parallel would still keep it at 100 rms each? with 4 speakers now?
                            That's correct. At any given setting on the volume knob you will also draw twice the current from your alternator/battery and the amp will run hotter. Car amplifiers (within reason) act like constant voltages sources. Running speakers in parallel means they each see the same voltage. To accomplish that the amp draws twice the current.
                              If the speakers currently connected to the amp are 4 Ohm speakers then they're currently recieving a max of 70watts, according to the manual
