Bose amp system
  • Bose amp system
    Does anyone have a clue how much wattage the factory bose amp puts out per channel
    my bose put out ~7 wpc @ <2 ohms IIRC to the door subs
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      thx that was a big help
        i would say anywhere from 7-13w
          sorry, i posted that in a rush. the spec i approximated was for the 8" woofers in my car. the two woofers are powered by dedicated amps. the subs are below 2 ohms which means that you can halve the power if you hook it up to a 4 ohm speaker. the upper freq. are handled by the head unit and are normal 4 ohm speakers. the rears are also powered off the deck and are 4 ohm speakers. keep in mind this may not be the same across the gm line, it's just waht i know for the the specific gm car that i have. warx was right with his range. i think the woofers see closer to the high value of that 13 wpc then the originally state 7 wpc. though i wouldn't doubt the 'twiddlers' and the rear speakers are down at around 7wpc
          M10k
          My Car Pc Install
          My Boat Pc worklog
            wow... really low powered....
            2006 Mazda 3
            Behringer DCX-2496
            JL500/1 JL10w6v2
