Should i run a long usb cable for audio?
  • Should i run a long usb cable for audio?
    I am getting interference over my audio cable from the USB DAC to the amp. Would it be better (in terms of interference) to run a longer usb cable from the PC to the DAC and a short cable from the DAC to the amp.
    If it was a choice of long usb and short audio cable or short usb and long audio (and all other variables remained fixed) which is better?
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
    I'd think the longer USB cable would be less susceptible to EMI than the long audio signal cables.
    I'm not the expert, though.
    How about the Wiki?
      I would have to agree with DP, however you need to indentify what this "interference" is. Please be more descriptive. Is it a constant noise, does it change with speed, is it only there when the car is on, etc etc...
      System always under construction
        It is a kind of quiet hissing which sounds like its picking up the sound from inside the PC. This is logical since the audio cable runs right next to the case. My install makes it near impossible to run it anywhere else which is why I was thinking I could move the DAC to the boot (trunk) and then run a very short signal cable to the crossover. This would mean the USB cable would run where the audio currently does, hopefully without picking up the same interference.
        VIA M10000
        512Mb RAM
        30Gb 2.5" HDD
        Silverstone USB DAC
        Consult (ODB)
        CarTFT K500
        Carnetix P1290
          Then your problem is something else. YOu have the silverstone DAC I see. Read through the last few pages of this thread. YOu will find your answers there probably.
            Cool thanks, looks like running it thorugh a powered hub might be my solution then
            VIA M10000
            512Mb RAM
            30Gb 2.5" HDD
            Silverstone USB DAC
            Consult (ODB)
            CarTFT K500
            Carnetix P1290
              Maybe, I should have pointed out the mod done to the card was a bigger improvement, but the hub idea might be cheaper and easier to try.
                Yeah, I already have a hub I plan to wire onto the 5v line from my Carnetix p1290 so I will try it on that and see how we go. The thing is it used only get this interference intermittently until I reshuffled wires (including running the audio cable near to the pc housing)
                VIA M10000
                512Mb RAM
                30Gb 2.5" HDD
                Silverstone USB DAC
                Consult (ODB)
                CarTFT K500
                Carnetix P1290
