somthings wrong with my system
  • somthings wrong with my system
    i can figure out wats wrong. the other day i got a 1000 watt sony xplod amp and a lightning audio 10'' and i had the mtx audio 10''. i hooked it all up with a wiring kit and then i turned the car on it started beating but when i went to turn it up for full bass the amp turns off and it gets really hot . i checked the ground wire and stuff it all seems to be ok . and now its turning off soon as i turn it on .(I NEED SOME HELP)
    you wired the subs incorrectly (most likely) do a search on how to wire a sub (parallel vs. series)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      Definitely true, your subs prob can't handle the resistance (ohms) that you're putting to them. They start overheating and the amp shuts down.
      www.computer-forums.net
        you got it a little mixed up. the amps can't handle the impedance of the subs, the amp starts to overheat and shuts down.
        M10k
        My Car Pc Install
        My Boat Pc worklog
          You're right, that's what i meant to say. I've been thinking about resistance all day (re-wiring my current system).
            i figured as much :-)
            M10k
            My Car Pc Install
            My Boat Pc worklog
