Wiring for the system
  • Wiring for the system
    Alright guys I finally bought all the components of the system:
    Eclipse CD7100
    ER18RNX Mids
    Peerless HDS Tweets
    Memphis Belle Amp
    Planet Audio BB-150.2 Amp (Tweets)
    Then the 2 8" AA Assasins
    Now I just need the wires for it but im not so sure on everything i need sooo that being said:::::
    What do I need for the following system wiring wise...
    ______________230x2@ 4 ohms bridged to 2 ER18RNX Mids
    Memphis Belle <
    ______________600x1@ 2 ohms to 2 8" AA Assasins
    Planet Audio BB-150.2 -> 150x2 @ 4 ohms to 2 Peerless HDS Tweets
    Id like to to do the Big 3 as well. I want this to be high quality wiring and such but not sure what all I should buy. Knuconceptz still the best place to pick up most of this stuff?
    And by the way the ER18RNXs and the Peerless Tweets are both 8ohm speakers so it will really be:
    ______________115x2@ 8 ohms bridged to 2 ER18RNX Mids
    Memphis Belle <
    Planet Audio BB-150.2 -> 75x2 @ 8 ohms to 2 Peerless HDS Tweets
    _______________________________________
    Also this will all be hooked up to an Eclipse CD7100 and be run active if that matters in the wiring... Any help is appreciated thanks!
    Check out www.the12volt.com. They pretty much have everything you'll need to learn in order to properly wire your equiptment, as far as proper wire gauges, speaker configuration techniques, and much more.
    PROGRESS:
