Newbi Question on Audio
  • Newbi Question on Audio
    Hey guys,
    I am in the process of gathering everything up to install my carpc. I already have my computer (see below for specs), wireless keyboard and Sirius satellite modification kit. What do you guys recommend me using to send an audio signal out? I was looking at the Turtle Beach Audio Advantage Roadie USB audio adapter but after doing more research I’m not sure it will work any better than their Audio Advantage micro. I would really like two sets of outputs (front and back). Does anyone have any recommendations on what I should use? I’m stuck.
    (My audio system: (1) KX600.4 amp driving (4) 6x8 Kickers with 1” tweeters, (2) KX1200.1 amp driving (4) L5 Dual Voice Coil 12’s)
    Enclosure
    • Automotive grade PC enclosure
    • Tough design with 5.5mm black anodized extruded aluminum
    • Integrated case fan for proper cooling
    • Four integrated mounting feet/tabs for installation onto any flat surface
    Dimensions & Weight
    • 8.4"(W) x 10.1"(D) x 2.25"(H)
    • ~4lbs
    Operating Temperature & Humidity
    • -10 to 60 Degrees Celsius (14F-140F)
    • Third party testing shows capable of -40C (-40F) cold starts.
    • 0% ~ 93% (relative humidity; non-condensing)
    Audio Subsystem
    • VIA VT1617A 6 channel AC’97 Codec
    • Full Duplex 3D Stereo Sound
    • Software AC '97 Audio CODEC
    • 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
    VGA & Video
    • Onboard Video, with full Motion Video Acceleration, Hardware MPEG2
    • Motion Playback at 30 fps.
    • Integrated VIA Unichrome AGP graphics
    • MPEG-2 and MPEG-4 Decoding Accelerator
    • Standard 15 Pin CRT Monitor Connector up to 1280x1024x24
    • S-Video & Composite Video Output Connectors (NTSC/PAL)
    Input & Output Ports
    • (1) RJ-45 LAN port
    • (1) PS2 mouse port
    • (1) PS2 keyboard port
    • (1) Serial port (external)
    • (1) Serial port (internal)
    • (2) USB 2.0 ports (external)
    • (3) USB 2.0 ports (internal)
    • (1) D-Sub 15 VGA port
    • (1) RCA composite video port
    • (1) S-Video port
    • (1) 1394 Firewire port
    • (3) Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
    • (1) Molex wiring harness connector with power, ground, ignition hot.
    LAN
    • VIA VT6103CL 10/100 Base-T Ethernet
    Operating System & Software
    • Windows XP™ Pro OS Pre-Loaded
    • Digital Dash Car PC Software Front-End
    CPU
    • VIA C7™ 1.5ghz NanoBGA embedded processor
    • 133mhz FSB
    • Low power consumption (<15W)
    RAM
    • 1024mb (1gb) DDR2 533 RAM
    Hard Disk
    • 80gb 2.5" Mobile Laptop Drive
    • 5400rpm rotational speed
    • Mounted on rubber-shock absorbing dampers
    • High non-operating shock tolerance by load / unload technology
    • FDB (Fluid Dynamic Bearing) motor for ultra silent operation
    • Vibration Operating 9.8m/s2 { 1.0G } (5 to 500Hz)
    • Shock Operating 1,960m/s2 { 200G } 2ms
    Optical Drive
    • Optional Slim Slot Loading External Firewire DVD/RW+ Combo
    System Board
    • VIA CN700 North Bridge Chipset
    • VIA VT8237RP South Bridge
    • Embedded Motherboard
    • Award 4 MB Flash ROM
    • 240pin DD2 DIMM socket w/locking mechanism
    • Wake-on-LAN
    • Keyboard Power-on
    • Timer Power-on
    • System power management
    • Power failure recovery
    Power Supply
    • Intelligent Vehicle Power Supply
    • ATX, 6-24V wide input range
    • Intelligent shutdown controller, powers on and off with ignition.
    • ON/OFF motherboard control
    • Survives vehicle engine cranks
    • Battery deep discharge prevention
    • High efficiency, 90 watts output
    • Works with 12V / 24V car batteries
    • "Anti-Thump" Amplifier remote control
    • 10A automotive fuse (mini-blade)
    Expansion Slots
    • (1) PCMCIA Slot - CardBus Type I & Type II
    • (1) Compact Flash Slot
    Ford F-250 Crew Cab Super Duty. Looking to install a full audio/video system integrated with a mobile computer.
