Simple OSD MasterVolume Display
  • Simple OSD MasterVolume Display
    Hello everybody!
    I write simple utility to display master volume when rotating VolumeKnob.
    I think it be usefull.
    Screenshots?
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
      ScreenShot
      New Osd Screen shot
        Nice! That's basicly what my laptop does.
        Greedy
        -Adj.
        Planning:
        [----------] 97.3%
        Parts Aquisition:
        [----------] 95%
        Install:
        [----------] 95%
          Originally posted by NicolaPr View Post
          Osd Screen shot
          That is very cool! I may have to give that a try!
          New System in progress:
          M10k
          Phaze TD1500 ~> Seas g18rnx/p
          Zapco Ref 500.1 ~ 12" tc-9
          Transflective Xenarc
          My Car Pc Install
          My Boat Pc worklog
            New Version of OSDProject
            Hello!
            Now OSDProject not only display MasterVolume but also show WinAMP - Now playing!
            Also you can change color for MasterVolume and WinampTitle.
            Good luck!
              OSDProject Version 0.3a
              Hello All!
              Some improvements added:
              SoundCard selector to see MasterVolume of active card;
              User messages from external apps (Demo+Sources);
              Minor bugfixes.
                this is nice..can i make a request?
                can you make it so we can select the X and Y of the OSD location?
                and how can we remove the title that reads the sound card name?
                  New version 0.4
                  Hello everybody!
                  I'm upload new version of OSD_Project with many improvements.
                  Look sharp!
                    wow.. perfect.. this is very nice actally, good work mate.
                    one small last request. i need to position the OSD away from something in RR that interferes with the OSD making it flash (RR ilists) so i need to position it a little more to the top, is this possible.?
                    thnx.
                    EDIT: forget about that request just found about the EXACT placing..this is perfect now
                      Update 07.10.2008
                      Hello, i made small update for this utility.
                      The new option is added: "Display WinAmpTitle when volume changed"
                      When this option is enabled, you can see TrackTitle any time after small change of soundcard volume.
                      Allso in archive you can find DelphiSources of small utility that can interract with OSDProject.exe.
                      Good luck.
                        Unicode support?
                        That's great!!! Soundcard selection is a great feature also!
                        Is there any chance that unicode support is added? I have many songs with greek titles and they're not displayed correctly.
                          Unicode
                          I shall try at leisure time, but is not assured that winamp can to give the correct song name in unicode.
                          PS: Mazonakis it is pleasant to me, what you will advise from the Greek executors in such style ?
                            OSD MasterVolume Display (Update)
                            Hello!
                            I have made some updates in my OsdProject.
                            First of all it is integration with GPS the receiver, thus the level of loudness will be automatically regulated depending on speed of the car.
                            In the main window of the program it was added few settings for VolAdjust.
                            The second improvement is effect of a luminescence at the text, you can change the size of a luminescence and color of a luminescence.
                            In this version there is a small glitch with display of the long text and also Unicode is not supported while.
                            PS: you need additional software such as ComSplitter or GPSGate, to use navigating software with OsdProject in same time.
                            Click image for larger version
ID:	2283713Click image for larger version
ID:	2283714Click image for larger version
                            Download:
                            OsdProject6.rar
                              Very Nice! I will give it a go. I really like your dedication to your product and to the community as a whole. Thanks for all your hard work! SNO
