how connect GPS wires with factory Audio wires
  • how connect GPS wires with factory Audio wires
    Hello boys
    I have Mazda 6 Non-Bose & i buy Gps devise the power cable come with 3 wires (yellow- red-black)
    where i will connected this 3 wires with original cable 4 factory audio ???
    i now Black wire for ground cable Black/Orange
    Red wire for 12 Volts but where connected ??
    Yellow wire for what and where connected ???
    and what the different between !!!
    12V ACC & 12V cons
    "12V cons" is a 12v power line that is always live (regardless of whether or not the car is on). (this wire is usually yellow in aftermarket audio components*)
    "12v ACC" is a 12v accessory line that is only live when the key is on the "ACC" or "ON" position. (this wire is usually red in aftermarket audio components*)
    *=those are common wire colors for aftermarket car audio components and other accessories, but there is no guarantee that your GPS unit uses this wire color standard. you should check the GPS unit's manual before connecting any wires.
    F150 Truckputer [1.0] (coming soon!)
    Fusion Carputer [2.0]
    Fusion Carputer [1.0]
      Thank u very much , i will check and reply
      thnx again
