purpose of sven4?
  • purpose of sven4?
    i was just wondering the purpose of the peripheral sven4. im installing a carpc in a bmw e46 and was wondering if it would be possible to connect the pc directly to the wires behind the HU.
    If i use a 3.5mm to RCA cable, and just connect all the left side wires(front n rear subs, tweeters, etc) together on one wire(red) and the right side wires(front n rear subs, tweeters, etc) on the other wire(white) to appropriate +/- terminals, would this result in bad sound? I plan on connecting an aftermarket amp later on, but using the factory external amp at the moment.
    thanks.
    2000 BMW 323i
    Carputer Installed:
    Lilliput EBY701 Screen
    Centrino Duo Laptop
    1.5GB RAM
    120GD HD
    iBus
    Centrafuse 2.0
    thanks.
    That is not the best/proper/correct way to do it. Search the forum, and check out the "show off your ride" section for your car.
    Michael
      Why not? He asked why.
      My BMW E46 carpc
      My iGuidance 4 skin
      FS transflective 2008 lilliput
        They're designed to be used with the OEM steros and aftermarket amps/speakers, not aftermarket stero (carpc) and factory amps/speakers - which is what I gathered you are trying to do.
          Currently I have the outputs of my usb sound card running into the stock wiring/amp but volume is low. Will a sven4 help this or how should I hook this up properly?
          My BMW E46 carpc
          My iGuidance 4 skin
            No. Use a line driver.
