Found noise source. Help me find cure.
  • Found noise source. Help me find cure.
    Here is my setup.
    I have Computer ---> Panasonic DSP ---> Phoenix Gold Line Driver ----> Bose Factory Amp.
    There is alternator noise and other interference (I can hear radio from noise). I have determined that the source of the noise is from the PG line driver. The problem is that i need this line driver because my DSP processor only output about 1V, so the volume is extremely low without it. Unfortunately this thing is a noise magnet. Here is how this line driver is making noises. The line driver has RCA inputs that is right beside the 12V power input. When these two cables comes close to each other there would be massive amount of alternator noise and radio interference. I have concluded that this is not a grounding problem, because i have tried grounding with battery, with harness, with chassis(right under the seats) and the result were the same. The only time there would be no noise is when the line driver is disconnected. So i'm looking for you guy's advices:
    1) How to eliminate noise from the line driver.
    2) How to shield my cables
    3) How about a small capacitor?
    4) Other things that worked for you
    Tomorrow i will try the following: wrapping the signal wire around the power cable, and get better RCA cables.
    thanks,
    Punky
    Upgrade you battery to chassis cable and your alternator to chassis cable.
    Failing that could be a poked line driver in which case you;re probably better of replacign than wasting time trying to repair it.
    Use shielded co-ax RCA cables if your system (presuming your system uses unblanced inputs/ouputs)
    Can't sheild DC power cables so don't bother trying.
    I wouldn't bother
    See reply #1.
      problem solved. by using one of these sucker http://www.canadiantire.ca/browse/pr...romSearch=true
        Care to show me the name of the product. The doesn't seem to work
          Put in a postal code. If you don't know any Canadian postal codes (like me) just type anything. It will complain if its not a good one and give you an example. Use that and it will work.
