Audigy 2 NX
  • Audigy 2 NX
    Anybody think the software for this card sux??? my sound with this card is all messed up...
    For the year or so I used the Audigy 2NX as my sound card, I didn't use the included software, and I actually thought the sound quality was quite good. It depends a lot what you're running it into as well though.
    My Grandma & Her Friends on Their Spring Vacation
      Yeah, I've seen the Audigy 2 NX in action. It works pretty damned good. maybe you have somthing that conflicts with it?
      Software Developed:
      DS-ATX Controller Interface
      Laptop Shutdown Controller
      Considered Projects:
      TPMS Interface
      Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
        My 2nx works great, but the my Tweets are crazy loud and i hardly heard the singing part of it... The EQ in the sound card is just BS... Just to get bass you have to turn on CCMS or whatever and then click on surround sound... well that makes that music echo... I have very powerfully system, so i hear it and i hate it.. When i had audio running thru the deck it was perfect..
          Are you set up for stereo or quadraphonic or what? Are you connecting your RCAs directly to the 4 channel AMP? Or do you have a graphEQ in between? What's your setup like?
          Software Developed:
          TPMS Interface
            What version driver are you using?
              How do you find that out?? Are you set up for stereo or quadraphonic or what??
              Here is my setup.. from the sound the front and rear is running into 4 channel amp and sub to sub amp.. No graphEq or anything.....
                The newest one, i just download from the site.
                  Ok, and are you set up for 5.1 then? Or are you setup for Surround Sound, Quadraphonic, or Stereo?
                  These will have huge impacts on how the sound is sent to each channel.
                  Software Developed:
                  TPMS Interface
                    I am setup for 5.1.... i tired all the option and sound is not good enough for me.
                      In that case, you could do what RedGTIV6 did in her car, you could get a DSP with a optical connection to it. Have that send your signal out to your amps. It's the same car that won SQ competitions.
                      Software Developed:
                      TPMS Interface
                        Also, you are missing out on the center channel. That may be why your sound is off as well.
                        Software Developed:
                        TPMS Interface
                          afaik, the friver only lets you choose between 4ch or 5.1 - you need 4.1 as you don't have a center speaker.
                          An alternative: set it to 4ch and use the line output of your 4ch amp to feed the sub amp. Use the sub amp's low pass filter.
                          OR
                          Search, try and try again, there has to be a solution...maybe using virtual audio cable (software)?
                          Good luck!
                          Joachim
                          List of front-ends/usefull apps
                          XTroniC | XTroniC Direct
                            OR
                            Good luck!
                            Joachim
                            If i were to do that then it will avoid the purpose to the external sound card.. going to 4 channel to sub amp. Also i will have no control over sub amp...
                              I use a Sherwood X-DTS80 from my sound card to my PG Octane 5.1 Amp. Though I am turning on the amp today. Wish me luck in getting the sound correct.
                              Software Developed:
                              TPMS Interface
