please please help me with this h/u question
  • please please help me with this h/u question
    i need some help here and nobody will answer me on the other forums. okay so i have a 98 mustang. this radio bezel has 2 single din slots. so i bought the bezel from a newer mustang which has a double din slot and installed it just fine. now i just have to put in the radio, but i can't figure out how to secure the dash kit to the cage that came with the radio, and then to the actual unit. the radio is an alpine w200.
    this is the dash kit, made by metra:
    http://i104.photobucket.com/albums/m...7205/10933.jpg
    and here is the cage:
    http://i104.photobucket.com/albums/m...MAGE_00010.jpg
    please help me!!!!
    Cant you screw some bolts on there?
      well i really don't know how to come about doing it. or if the cage wraps agound the unit then goes into the dash kit or if the dash kit wraps around the unit then goes into the dash kit. if i do it the first way i don't see any way to bolt it on.
        Well how about small flat head bolt and nuts. Insert the bolt from the inner side of the cage, then if you need to, drill a hole on the plastic dash kit, then put the nut on it.
          [quote=jash7;1183012]this is the dash kit, made by metra:
          [media]http://i104.photobucket.com/albums/m161/jash7205/10933.jpg[/media]
          Exactly. You don't need the cage in this case. The screws should have come with the unit. They screw directly into the sides of the radio through the kit. You should see that they line up with at least a couple of the holes in the kit.
          System always under construction
            yeah guys i figured it out. the radio just didn't come with them cause i bought it open box. anyway i found some replacment skrews. thanks anyway guys
