protect light is on my amp
  • protect light is on my amp
    i need help... i have a 300 watt Jensen amp and 2 12in insignia subs. my amp was workin good for about 1 week and then me and my bro hooked up a kenwood 600 watt amp to them to see if it would work. but when we hooked my old amp back up the protect light was on. i was wonderin if anyone has any suggestions, i would really appreciate it.
    open your speaker box, check all the wires to see if the positive and negative wires have somehow come in contact causing your amps circuit protection to light up.
    Check out my CARPC: Project Diamond Plate
    Quick Reference:
    CPU Electrical Specs
    Power Supply Calculator
    Video Connections for newbies
    Temperature Converter
    Voltage Calculator
      sounds like an impedance problem. how did you wire the two subs to the amp?
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        they are unbrigded right now. I had them brigded when it was working properly.
          we need to know more. specs on the amp, specs on the sub (voice coil amount and impedance)
          M10k
          My Car Pc Install
          My Boat Pc worklog
            Key Features (AMP)
            Amplifier Type: Dual Channel
            Bass Boost With Bass Boost
            Bridgable
            Power Output:
            RMS Power at 4 Ohms75 W x 2
            RMS Power at 2 Ohms100 W x 2
            Performance:
            Bass Boost Frequency = 45 Hz
            Other Features
            MOSFET amp Yes
            subs are 12in 400 watts 200 RMS
              There are only 2 possibilites: wiring issue or equiptment failure.
              If you have a meter check the impedances of the speakers that they are correct and not shorting out.
              Did you accidentally wire in the power wires incorrectly or backwards at any pont when you were reinstalling the amp? Doing that on some amps, even for a sec, can destroy a good working amp.
              PROGRESS:
                Simply put, I had this issue when the positive and negative wires on one of my speakers touched each other. What happened was that somehow I broke the thing on the speaker that holds the two terminals for the speaker wire.
                I'd try disconnecting each speaker wire from the amp, one at a time, and by process of elimination, see which speaker is causing the protect light to come on and then start by checking the connection to that speaker and follow the wire back to where it connects to the amp looking for problems with that wire.
