2 ch sound card + 5 ch amp - will it give me 5 ch sound?
  • 2 ch sound card + 5 ch amp - will it give me 5 ch sound?
    Hi guys, sound is not my strong side, so I'm kinda lost in here. Right now my carpc is hooked up to the sound system thru HU->Aux Input. I'm planning on loosing HU and use carpc thru amp. But here is a question I cannot understand. If I use onboard 2 ch sound card hooked up to a 5 channel amp (4 speakers + sub), will it give me 5 channel sound or not?
    Thanks in advance.
    Nope.
    How about the Wiki?
      what if I'm gonna use SC with SPDIF ?
      Or how can I power 4 speakers and sub and get 4.1 sound?
        SPDIF will work, but you're going to need a DAC of some sort.
        You can try splitting and re-splitting the simple stereo, but I honestly believe the output signal will degrade enough to make it not worth your while.
        How about the Wiki?
          I use an external usb soundcard, works ok for me
          http://www.maplin.co.uk/module.aspx?...=97120&doy=8m5
            it drives me nutz.... I cannot figure out what do I need to make 4+1 sound (
            I have a pc with onboard sound which is 2 channel I believe. It's Sound Blaster, AC '97.
            I also have USB sound card Thurtle Beach, which is 5.1.
            What do I need to get 4.1 sound? (4 speakers + sub)? Do I need 5 channel amp (one speaker per channel + another amp for sub)? How do I hook up amp to PC Sound Card?
            Sorry for stupid questions,
            Thanks in advance.
