Power for JL A6450/PC/future amp
  • Power for JL A6450/PC/future amp
    I just ordered a JL a6450 for my 07 saab 9-3. because of the funky saab setup, i needed this amp just to power the speakers in the car.
    I'm gonna run my front dash speakers (boston s35) on ch1/2 with [email protected] and my rear deck (boston s45) with same filter on ch 3/4. then on 5/6 i plan on running my door 6.5s with a lp @150-200. i have yet to purchase new door speakers but am probably gonna go with some mid-bass drivers of sorts. havent decided. any suggestions?
    well my main question is this... the amp manual states i need at least a 4gauge power to it. I planned on running to a distro block for my pc and the amp and in the future a sub amp. what guage wire should i run from the battery? will 2 suffice? or do i need to go down to 0/1? or heck does 4 work? i dont have my pc yet, but i am 99% positive itll be a m2-atx power supply.
    basically i dont want to run a wire through my firewall and then find out that i need a bigger cable 3 months down the line when i add a sub amp. i plan on only powering a single 8" or 10" sub in the trunk.
    any suggestions?
    I would recommend 0 gauge wired. Overkill is always good.
      ive got a 2g in my trunk going to my cap then out to two amps and the pc just run the thinkest you can get
      MY build...a walk thru, finally getting to it
        I'm thinking...
        2GA w/80A fuse to the distro block in the trunk
        4GA w/40A to the JL a6450
        8GA w/20A to Future Sub Amp
        8/10 w/(fuse?) to CarPC
