Lights are still dimming with a 2.5 farad cap!
  • Lights are still dimming with a 2.5 farad cap!
    I have a Pioneer GM-X802 class A amplifier. 300wrms, two 20 amp fuses.
    When I installed it, I had a .5 farad capacitor and the lights dimmed when I pushed the amp. I picked up a 2.5 farad cap today and the lights are still dimming. Is this an issue of a capacitor can only help so much or is this class A amp drawing way more than I'd expect?
    Thanks in advance!
    1997 Grand Prix GTP - Pioneer Premier HU - Alpine 4ch for mids/highs - McIntosh separates in the rear (soon to be in front as well) - Custom Passive Xovers - Pioneer Class A 300wrms amp - 2.5 farad cap - The original RF "The Punch" Pro Series 12"
    which lights are dimming?
    and i doubt a cap will help at all..
    if its your headlights you are talking about sounds like you need a bigger alternator or a smaller amp.
    what is the amp powering btw.. sub? mids?
    if its a sub i would have though a class A amp would be a bit overkill for the job, and not the best choice of amp
      there is no way that the pioneer is a class a ;-)
      what kind of wiring do you have? (gauge) and how are your ground points? did you upgrade the big 3?
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        I got a steal on this amp. $20 on craigslist! Its a GM-X802. If you search ebay for completed items you can find some pics of it. It says Class A right on the front of it.
        I am using 8-guage wiring all around. The ground point is the end of a factory bolt that i put a wingnut on. I crimped an "eyelete" on the end of the wire and put it on the bolt. Due to the fact that this amp's connectors doesnt like smaller wires, both the power wires and the wires from the cap are connected to it. so basically it looks like this (its too late to bust out the digi camera):
        power source====amp====cap
        And yes, this poor amplifier is pushing my dear old 12". From a power standpoint, I realize a class A amplifier is the worst choice but i'm happy with the amount of power, it sounds good, and hell it was only $20
        The guage cluster lights are dimming and the headlights are ever so slightly as well. You have to pay attention to notice the headlights.
        While typing this up, I realized that I did make a "mistake" in the +12 power line... Its connected to the factory line since the battery is buried in the engine bay. GM used either 6 or 8 awg wiring. I doubt that I put an additional ground wire on the battery as well. It looks like I have a 105 amp alternator in this puppy.
          Where you grounded to the chassis, did you strip the area down to bare metal?
          And where would GM use 6 or 8awg, other than a line from the battery to fuse box or starter?
          What "factory line" did you tap into?
          How about the Wiki?
            You need better battery. Capacitor without good battery will not do anything good...
            Try:
            -Add wire from battery - conntact(ground) to ground in car.
            -With multimeter mesaure how V(voltage) you get on battery when car is off and how when on.
            -With multimeter mesaure how V(voltage) you get on amplifier when car is off and how when on.
            Im fix my problem with new battery(70Ah and 2500A) and aditional ground cable(AWG 0) from battery ground terminal to car ground...
              DP - I will have to verify if the ground in my trunk is stripped to bare metal or not. I know I was in a little bit of a rush to get it all installed to begin with. The "factory line" I was talking about goes from the battery to a bolt (often used for jumping a car, also where my power to the amps/carputer is attached) to the fuse box.
              Dejan - Good call on seeing how much of a voltage drop I have. I'll try wiring it up correctly when I get a chance
              BTW, Here's a link to what the amp looks like.
                I had this problem in my car for ages, albeit with a much more powerful setup (2000WRMS going to the subs alone!)
                Fixed by putting in an optima yellow-top battery on a split-charge into the system. As I have now learned and have been told many times by people in the industry, capacitors are a waste of money in most circumstances!
                  A capacitor is basically a way to supply excess power over a very short period of time. Once drained, it must be refilled. This has to take place very quickly, like between beats.
                  If your alternator cannot supply the power, it comes from the battery. Therefore, a better battery will help or a better alternator will help but a bigger capacitor usually doesn't solve the problem.
                  Want to:
                    and if the battery is too big then you may get the next problem of it not charging up properly too.
                    just checking you did run a new positive power wire from the battery terminal to your amp?
                      i remember a guy coming to me once saying his stereo sucked and could i fix it.
                      he had wired it up himself with sticky tape and phone wire and was confused when it wouldnt go very loud.
                      after putting the proper size wire in. he was most happy
                        scrap the cap and get a optima battery under the hood yellow top is the best for stereo but they all work well. if that still doesnt solve your proble try a kinetik battery for the stereo jmo
                          Basics first, do the wiring correctly, do a dedicated fused power wire to the amp(s) and a 4 Gauge or better ground, as short as possible.
                          Do wiring first, battery second, then go from there if there is a problem still A new alternator is a stretch, that amp does not pull that many amps to require it..
                          Ours is the age that is proud of machines that think and suspicious of men who try to.
                          ___________________________________
                          Current SYSTEM
                          AMD64X2 2.5
                          Xenarc
                          ZAPCO DSP-6
                          ARCAUDIO SE Amps
                          Rainbow Profi CS365 & Profi Vanadium 12"
                            not the solve all. sounds like you need a big three upgrade...
                            http://forum.sounddomain.com/ubbthre...e/1#Post312025
                              I have a cap in my car and it's been a while since I wired it so I might be wrong but....
                              Shouldn't it be Power source (battery) >>>>> Cap >>>>> amp??
                              I don't think wiring the amp like you listed above will utilize the cap.
