DAC, multiple outputs?
  • DAC, multiple outputs?
    Hello,
    I am using a VIA M10000 and looking at using a DAC to get sound to my two amps.
    One amp is controlling my front left and right comp set (passive x-overs), another amp is just for the subs.
    I would like to have a DAC go from the PC to each amp. Is this possible? Or do I need two DACs (One for each amp).
    Is it possible to get a Bloat DAC with multiple RCA outputs?
    (Trying to grasp my options).
    Thanks!
    Not sure if I'm completely getting your setup but I think I have something similar. I have a 5 channel amp that outputs to a crossover for my highs, mids, and sub. From the crossover goes to my dac which is then connected to the computer. I don't believe you would need more than one dac but that is just me..
      Sorry not a very good description of my setup (heres a quick MSpaint version of what I was hoping to be able to do)
        there aren't any multi-chan dac's out there that i know of. well, they have multi chan ic's but not a dedicated dac. your best bet would be to go with a bloat or twisted pear dac into the stereo input of your amp, then use the amp's pre-outs to get the signal to the subs. the drawback is that you'll have to use the amp's x-overs but depending on your setup, it could be just fine
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          Hi Scott_fx,
          Thank you for the suggestion. Unfortunately I'm having a hard time understanding. Are you saying, wire from the DAC to the 4ch amp then to the 2 channel amp?
          Thanks,
          Incudie
            yup, what amp do you have? some amps will have a pre-out that will pass the original signal on to another amp. another option is just to get rca y-adapter that will give you two identical stereo ouputs as well.
            M10k
            My Car Pc Install
            My Boat Pc worklog
              sweet thanks. I have an
              Ipaul 4.300
              http://195.243.203.21/rainbow/techni...112112&lan=ENG
              Actually, I have not purchased the other amp for the sub yet
                http://www.talkaudio.co.uk/index.php...d=212&Itemid=1
                -RCA inputs for four channels plus RCA throughput sockets
                looks like you're good to go. nice amps btw...
                hmm... if you're going the route of rainbow amps... what speakers are you going with?
                M10k
                My Car Pc Install
                My Boat Pc worklog
                  Thank,
                  SLC 265 Kicks =)
                    you should just run active and screw the dac :-)
                    M10k
                    My Car Pc Install
                    My Boat Pc worklog
                      That is what I've heard in the past... Active Crossover? How does that connect to the computer? Is that some kind Equalizer or are those completely different? (JUST finished sound deadening my passenger door...)
                        Ok doing a little more research... I *think* I would still need a DAC.
                        Would Go:
                        PC > DAC > Active Cross Over > Amps > Speakers
                        Or do active crossovers have some kind of DAC built in? (don't believe so).
                          Would Go:
                          Yeah that's what my setup looks like right now, don't believe they have built in dacs
                            look into the behringer DCX2496 (what i have) or the alpine h701 (had this in my last setup) for a more streamlined solution
                            either will be perfect for mids, tweets and a sub.
                            M10k
                            My Car Pc Install
                            My Boat Pc worklog
                              Thank you for the recommended main-stream devices. (looking at the manual for the DCX2496)
                              http://www.behringerdownload.de/DCX2...PECS_Rev_C.pdf
                              If I am reading this correctly, is there an S/pdif input?
                              I have a spdif port on my M10000, would that be any better or worse then using a bloat?
