whine in speakers, don't think ground loop
  • whine in speakers, don't think ground loop
    This is my last problem till I'm totally satisfied with my little system.
    I get a high pitched whine in my speakers. If I tap the wires to the mic I also get crackles and loud buzzes. I'm using audio sockets soldered to wires since I built my own case so have no proper front panel.
    I think the mic has one channel and a ground. Yet the mobo manual says:
    Pin Signal
    1---MICIN1_L
    2---AGND
    3---MICIN1_R
    4---+5V
    5---LINEOUT_R
    6---LINEIN_R
    7---LINEOUT_L
    8---LINEIN_L
    9---HPOUT_R
    10--HPOUT_L
    11--SENSE_A
    12--SENSE_B
    13--CEN_OUT
    14--LFE_OUT
    15--SSROUT_R
    16--SSROUT_L
    17--SPDIF_IN
    18--GND
    1 & 2 are MIC IN L & R. Can there be a stereo mic or lines for 2 mics? I have pins 1 & 3 wired to my mic socket. I have pins 2, 5, and 7 wired to the speaker socket. wiggling any of those wires will change the whine. Touching the connector nubs sticking out of the mic socket makes a loud buzz. I can hear the mouse move. I think I must have the wrong pins, but no soldering iron on hand to experiment.
    I had pin 2 wired to the mic & speaker, but took it off the mic hoping the problem was that simple, that they shouldn't share ground.
    Thanks for any help!
    VIA Epia PX mobo (VIA C7 1Ghz CPU), 1gig DDR2 667, 4gig ATA SSD, Xubuntu 8.04
