usb soundcard with rca out?
  • usb soundcard with rca out?
    hi
    im looking for a USB soundcard for my laptop that will have RCA outputs to run to my amp
    i simply cant find any anywhere!!
    the jack-rca cable i have at the moment isnt any good, you go over bumps and it gives a hiss becuase the jack cable isnt a great connection for on the move?
    Thanks in advance
    Have you done any searching?
    Try Here
    If you can dream it you can build it ( I think )
    Build File
      that has RCA line in's not RCA line out's ?
        Actually if you look at the unit you will see it has RCA Line outs.
        Look Here
        Build File
          usb dac
          New System in progress:
          M10k
          Phaze TD1500 ~> Seas g18rnx/p
          Zapco Ref 500.1 ~ 12" tc-9
          Transflective Xenarc
          My Car Pc Install
          My Boat Pc worklog
            Look Here
            With this USB Soundcard I can hook my car speakers up to my carpc and get sound?
            {carpc to usb soundcard to 4 channel amp to speakers}
            If so how do you get the amp to turn on with the pc? Since there will be no radio head unit to hook the little blue remote wire to amp to turn it on? Sorry for noob question I'm still trying to find out how to hook my speakers up to my carpc without a head unit.
              ESI-audio
              http://www.esi-audio.com/products/
              System always under construction
