How should I hook up these amplifiers?
  • How should I hook up these amplifiers?
    Here are the three amplifiers I have:
    Pioneer GM-X372 = 240 watt peak, 2 channel
    MTX Thunder 4244 = 240 watt RMS, 4 channel
    Rockford Fosgate P325.1 = 325 watt RMS, 1 channel
    12 inch Rockford Fosgate HE2 subwoofer in ported box
    Stock speakers - 2 6.5 inch front, 2 6x9 rear
    computer, onboard sound, no headunit
    Specifications:
    Pioneer GM-X372
    Key features:
    - 2 x100 W or 1 x 240 W (Max.Power)
    - Load impedance capability ( 2- 8 Ohm)
    - High Voltage Input (200mV - 6.5V)
    - Speaker Level Input
    - LPF: 80 Hz, -12 dB/Oct
    Bridgeable Power Amplifier
    PWM regulated MOSFET power supply
    2 channels
    Load impedance capability: 2-8 Ohm
    Speaker Terminals: Screw-type
    Power / ground terminals: Large screw-type
    LPF: 80 Hz (-12db/oct)
    High voltage input capability: Yes (200 mV -6.5V)
    High performance balanced isolator circuit
    MOSFET output section
    Maximum Output Power: 2 x 100 W oder 1 x 240 W
    DIN power output (W)
    (DIN45324, +B = 14.4V): 2 x 70 or 1 x 200
    Cont. power output (RMS), 14.4V (20-20kHz/4ohms): 2 x 50 W
    Cont. power output (RMS), 14.4V (20-20kHz/2ohms): 2 x 60 W
    Cont. power output (RMS), 14.4V (Bridged 4 ohms): 1 x 120 W
    Frequency response: 10 - 50.000 Hz
    Input level control: 200 mV - 6,5 V
    Distortion: 0,008 (10 W / 1kHz) %
    S/N ratio: 100 dB
    Max. current consumption (A/4ohms): 14.4
    Chassis size (W x H x D): 255 x 50 x 169 mm
    Unit weight: 2 kg
    MTX Thunder 4244
    Bridgable
    RMS Power at 4 Ohms: 45 W x 4
    RMS Power at 2 Ohms: 60 W x 4
    Frequency Response: 20 Hz - 20000 Hz
    Signal to Noise Ratio: 100 dB
    THD at Rated RMS Power: 1 %
    Crossover / Equalizer
    Without Bass Boost
    Input Voltage: 12.5 volt
    MOSFET Circuitry
    3 Way Ready
    Width: 9.2 in.
    Depth: 9.75 in.
    Height: 2.1 in.
    Number of Channels: 1
    continuous power:
    - 175W x 1 @ 4-Ohms RMS
    - 325W x 1 @ 2-Ohms RMS
    Bridgeable: No
    Crossover Controls: High-Pass (HP): 40-400Hz 12dB/octave Butterworth
    Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
    Tone Controls - Bass: 0dB to +18dB @ 45Hz
    Signal Input - Low level: 1 RCA pair
    Signal Output Low level: 1 RCA pair
    Power Wire Gauge: 4 AWG
    Speaker Output Connector: Screw terminal barrier strip
    Speaker Wire Gauge: 8 AWG to 18 AWG
    Heat Sink Type: Cast aluminum
    Cooling: Convection
    Remote Controls: Punch Bass EQ (included with cable)
    Visual Indicators: Power On
    Signal Level
    Thermal Status
    Speaker protection
    Circuit Topology Class: Class-bd
    Frequency Response: 20Hz to 20kHz +/- 0.5 dB
    Shipping Weight: 11.5 Lbs. (5.2 Kg.)
    Dimensions (HxWxL): 2.1 x 11 x 11.7 (in) 5.3 x 27.9 x 29.7 (cm)
    Dual 2 ohm or Dual 4 ohm
    Polypropylene cone
    Bart foam surround
    Aluminum voice coil former
    Flat spider with stitched leads
    LXursion basket
    Consealer gasket
    Rubber magnet boot
    Spring binding posts
    High power handling
    Small sealed/medium vented enclosures
    Silver/black chrome cosmetics
    Power: 200 watts RMS, 400 watts peak
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    use the mtx for the 4 stockers (probably will blow them pretty quick but then you get an excuse to upgrade) and the rockford amp to the rockford sub.
      I don't see any reason to use the Pioneer amp at all in your setup. run each stock speaker off of the 4244 and run the sub off the 325.1
      for your power wires: the 325.1 uses a 40A fuse, the 4244 uses two 25A fuses (=50A), so your power wire needs to be able to handle ~90A. you can use a 4awg (or thicker) power cable from the battery to a 2-fuse distribution block, and you can run 8awg (or thicker) power cables from the distribution block to each amplifier. (or you could run two separate power cables).
      good luckl
      F150 Truckputer [1.0] (coming soon!)
      Fusion Carputer [2.0]
      Fusion Carputer [1.0]
        good luckl
        Ya, this is what I've been running for the last year but I picked up the Pioneer amplifier thinking I could use it in my system. Oh well, guess I'll throw in in the closet. Thanks!
        Ampie Case
        256 MB DDR2 PC5400
        M2-ATX-HV
        2005 Honda Civic
          well, you can use it if you really want to...
          you can use it to replace one of your other amps (which would be pointless as they areboth more powerful then the Pioneer amp), or you can add two more speakers and use the Pioneer amp to drive them.
