new guy
  • new guy
    my amp says to run atleast 4 ohms bridged. my sub is dual 4 ohm, how do i wire the sub so the amp is running at 4 ohm,do i just hook up 1 voice coil to the amp? i appreciate all answers,thanks
    help on hooking up 1 15 inch dual vc kicker cvr to a punch 801s 2400 watt amp?the amp says 4 ohm min bridged,how can i wire the sub so the amp will run at 4 ohms,is it possible to run the sub with just 1 vc hooked up?
    Where is the PC in your setup?
    You do realize that's what these forums are all about, don't you?
    How about the Wiki?
      Ok you can only run the sub at 2ohm or 8ohm if your amp is 4ohm min then run it at 8ohms you can find all these wiring diagrams at http://www.the12volt.com should have all the info you need. if you have any ?? PM me ill help you out
      2008 Jeep Patriot
      7in Lilliput
      1.6 Atom Jetway Board, 2gb Ram,
      Sound Blaster External Sound Card,
      RE Audio Coaxials, RE Audio 12in Sub,
      USA Amps Amplifiers, Centrafuse.
