factory Bose amp
  • factory Bose amp
    I have a 2005 Escalade Ext with a factory Bose amp. I removed the factory radio and relocated the climate controls to the center console, to make room for the 10.4" touchscreen. If I use the GMOS-04 wire harness adapter with the RCA cables, and connect those to the carpc, will I then be able to get sound through the factory Bose speakers, and factory Bose amp?
    Its designed to work but has VERY poor quality control. Expect some issues and be surprised if it works correctly from the start. Expect TONS of ground loop problems.
    Keep in mind that you MUST use the bose amp with the bose speakers. Plan accordingly if you plan on replacing any of the factory speakers.
    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
