protection light
  • protection light
    Gotta quick question thats been bugging me . I had my subs and amp hooked up for awhile i recently had to take them out for a couple weeks. When tried to put them back in I hooked up the power wire and red protection light came on my amp. When i hooked the ground up the light turned off all together (usually green for power). Any one that could help me out i would really appreciate it. Thanks
    I'm anal about the process I do things in... Ground always gets hooked up first, IMO...
    But this very well could have been an indication you had a bad ground. (assuming there was some form of metal-to-metal chassis grounding at the time)
    Play with it, 'til it's broke.
      This has actually happened to me before.
      With me, the light came on because it was actually getting grounded through an RCA cable. Even after I plugged in the real ground, it wasn't turning on.
      The issue ended up being that I conencted one of the speaker outputs to the head unit's amp-on wire accidentally.
      I would definitely check ALL your wiring.
      My Nearly Complete Car:
      http://www.mp3car.com/vbulletin/show...ed-car-pc.html
      Micro Control Center... Control Your Car Across the Internet
      http://www.mp3car.com/fusion-brain/1...-internet.html
      Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
      http://paulfurtado.com/
