Connect a hard drive directly to a Stereo...But wait...there's more!
  • Connect a hard drive directly to a Stereo...But wait...there's more!
    Ok, so I plan to buy a new stereo for my sound system, currently in progress. Let's say that this stereo will accept Ipods, thumb drives, etc.
    Let's now say I have 250gb of music, and I want to keep it on a laptop/external hard drive in the car, and be able to access the entire library from the drive.
    Let's then say that I want to mount a button on my dash that will tell the hard drive to look for my wireless network, and sync new tracks off of the media server overnight.
    Any ideas? Could really use some tips here.
    Budget is less than or equal to 500, I have several laptops and PCs on hand, so tech shouldn't be an issue.
    Thanks!
    Ride Runner and Enforcer's Upd8te plugin will do what you want.
    Want to:
      Originally posted by Bugbyte View Post
      Ride Runner and Enforcer's Upd8 plugin will do what you want.
      Thanks, but i really don't know what any of these do. Can you explain?
        Originally posted by Enforcer View Post
        Doesn't need RideRunner, there is a standalone Upd8 app.
        I still don't really understand what any of those do.
          Well the assumption is that you are using a computer, seeing this is a forum for running computers in the car.
          With that assumption that are pieces of software that will let you do what you want.
          If you are not using a computer, which I am starting to suspect, they will not help you.
          And TBH honest there is nothing that will allow you to press a physical button that will tell a standalone harddrive to connect to a wireless network and sync music.
          Actually nothing was not quite the right word to use, should have said nearly nothing, because you could use a computer.
            Yeah, that's why I'm pretty much ambivalent to whichever solution.
              http://en4cer.co.uk/joygov.shtml
              Want to:
                Go to Ebay and look up Media Hard drive enclosure you should be able to rig somthing very easily with adapters and what not to the stero. I'm not sure about the wireless Sync though. Really though how often do you update your collection?
                  Actually you can do (most of) that without a pc. I am running a hard drive (160Gb) with my head unit and keep it in the glove compartment with velco so I can detach it any time for an update. I know that Pioneer USB head units support up to 250Gb or 15,000 tracks, max 500mA current (but you can always add an additional and cheap 12v to 5v USB converter).
                    Depending on car and stereo removing the headunit could be a challenge. If you have modern car (<8 yr old) this thing could be what you need.
                    http://gromaudio.com/store/usb_adapters/index.html
                    Car pc integration with ease
                    Car mediacenter
                      Is there some sort of file/folder structure required to do this? And does it take long for the HU to search amongst 15,000 tracks?
                      Check out my CARPC: Project Diamond Plate
                      Quick Reference:
                      CPU Electrical Specs
                      Power Supply Calculator
                      Video Connections for newbies
                      Temperature Converter
                      Voltage Calculator
                        depends on the HU how well it works. My brother has a Kenwood HU in his car with a USB interface, the display is only a single line so he said anything much larger than the 4GB USB drive he has on it would probably be painful to navigate.
                          Thanks for the reply. However megarock says that there are "PIONEER USB head units that support up to 250Gb or 15,000 tracks..."
                          I don't think there's a head unit in the market today, with enough processing power that could swiftly thumb through 250 gigabytes of mp3 tracks. There must be a breakthrough in technology. Seriously, can someone prove otherwise?
                          Quick Reference:
                          Voltage Calculator
