Fuses blown, can someone tell me how I should wire this amp/sub combination?
  • Fuses blown, can someone tell me how I should wire this amp/sub combination?
    http://cgi.ebay.com/ebaymotors/2-ALP...4506.m20.l1116
    http://cgi.ebay.com/ebaymotors/ws/eB...2631&viewitem=
    I just had a shop install the amp and the subs two days ago and it sounded really good. On the way home tonight the subs just stopped working and when I got home, I found out that 2 of the 3 25w fuses blew. Maybe I can rewire it somehow so that I won't have this problem.
    Take it back to the shop. installing incorrectly should be covered under warranty.
    RevFE
    My Shop
      Fuses are rated in amps, not in watts.
      If the fuses are popping, then something isn't right.
      If a shop installed it, take it back to that shop to make it right.
      How about the Wiki?
        Did you buy the amp there as well?
        The amp can't draw more than aprox 1100 w at max load.
        3 x 25 = 75A
        75A * 14V = 1050 Watt
        Allso, never ever bypass fuses... you can seriously damage electronical equipment, or even start a car fire... (And most likely, the insurance will not cover it).
