Help wiring into stock amp wiring harness
  • Help wiring into stock amp wiring harness
    I have a soundblaster live 5.1 card I need to hook up to my car's stock infinity amp wiring harness. The harness is the only input/output on the amp. I need to wire two stereo cables into it.One for the front speakers, one for the rears. I have the sub taken care of. How do i splice these stereo cable into the harness. I know what colors the wires are and everything, I have the speaker wiring diagram. Any help would be appreciated, I'm tearing my hair out.
    Electronic Space Foot
    Being that you already know what colors are what, you will just need to make sure that the amp accepts a low level input, instead of a high level, if it takes a high level, none of this will work. If it does accept a low level input, then cut the headphone cable there should be 2 wires a shield. the wires are the left/rightpair, and the shield is ground. the ground will need to be wired to both negative speaker leads, and the left / right should be to the positive leads. wire colors change between manufacturers, so it would be best to check which is which before hard wiring anything.
    next project? subaru brz
    carpc undecided
