Blaupunkt Brisbane help
  • Blaupunkt Brisbane help
    hey guys
    I'm planning on running my CarPC thru my brisbane stereo.
    Does anyone know where I can get the faceplate pinout?
    I want to "relocate" the faceplate since my OEM audio is in the trunk.
    PS. it's got 16 contacts on the male/female plug
    2000 E46 330i
    Carpc - Dual Core Atom, 1.6Ghz, 1Gb RAM, Xenarc 7", Gps Mouse, Elm327
    I don't suffer from mental illness, I actually enjoy mine!
    If you are just extending the faceplate, there is no need for a pinout. Just need to keep track of which wire you connect to which pin (the connectors will be mirror images).
    http://www.mp3car.com/vbulletin/car-...extension.html
    Unless I misunderstood you?
      thx for the link.
      i also want to run the on/off function to my screen so it turns on with the stereo
      2000 E46 330i
        Originally posted by spoolup View Post
        thx for the link.
        I don't understand what you are asking?...
          when i turn the HU on i want the screen to come on as well...
          2000 E46 330i
            i am assuming you mean your computer screen?
            you should be able to use a relay off of the remote turn-on wire, the relay is just in case teh screen draws more than the remote wire will supply.
            next project? subaru brz
            carpc undecided
              that's kinda what i'm leaning towards. i just want to find the pinout to run the relay from the faceplate's on/off button.
              2000 E46 330i
                You would just use the remote wire from the wire harness in back, it sends 12vdc when the deck is turned on.
