Alternator Longevity
  • Alternator Longevity
    I just found out my alternator is trashed on my 2005 Ford Explorer.
    I bought a new Yellow Top and am getting the alternator replaced. I have an extended warranty that will only cover the OEM alt.
    My questions is: Do you think I will trash the new alternator given it is probably the same specs as the one that burned now?
    Did my system kill the OEM prematurely? I have 2 Alpine amps... A 4 channel and 2 channel (pushing 2 10" Alpine subs) plus my car pc.
    And, if I have to have an OEM alt, is there something else I can do to supplement power so I don't kill it too?
    Thanks!
    My System (2005 Ford Explorer)
    Intel D945GCLF2 Mini-ITX Mainboard
    2 GB RAM
    250 GB hdd
    500 GB USB hdd
    M2-ATX
    D-Link DWL-121 WiFi
    OBDII Elm327 Bluetooth
    Lilliput EBY701-NP/C/T
    Depends on how many amps you are drawing. If you are drawing a significant amount of the capacity that the alternator is able to provide, yes, you could shorten it's life.
    How many amps is your alternator? How many amps does your system(s) require?
    The only option would be to get an aftermarket alternator that is bigger. Capacitors and bigger batteries don't solve this problem.
    Want to:
      I'll second that statement. Capacitors will do nothing to help an electrically underpowered system. It was thought for many years that a cap would help to cushion heavy quick draws of amperage, but it has been proven that this statement is in fact false. Alma Gates removed all of the capacitors from her record holding SPL Bronco because she discovered that her SPL was actually higher without them in the system and that they were nothing more than another load on the system. The only benefit to a cap in a car audio system is that it helps to filter out some A/C ripple and in effect some noise, but in reality any cap more than 1 or 2 farad is completely pointless, except for maybe some show "bling".
      Data911 M5 system
      RR and iGo8PC
      Pioneer head unit
      Pioneer DEQ-9200 digital processor
      Phoenix gold line drivers
      Ultimate and Visonik amplifiers
      SMT 3 way active front stage
      Digital Design sub woofers
      3 runs of 0 gauge wire
        eh you aint pulling that much i would say.
        trashed? as in how?
        rebuilding them is eazy most of the time.
        But i havent killed mine yet and i have 2 batts, 2 amps, and a carputer.
        Gen4/5 (which ever you have) alts are usually pretty good.
        Core duo
        1tb harddrive
        256 ddr
        8 lilliput
        bu-353
        still installing...
          So I've made some phone calls to local car audio install shops that tell me I should be OK w/ the yellow top and a new stock alternator. Autozone had one w/ a lifetime warranty (130 amps) so I figure if I toast it again I can get it replaced for free... Hopefully.
          I wonder how I can tell EXACTLY how much my system pushes/requires and how much my Explorer requires?
          Or better yet, how can I monitor the alternator so I know if it is struggling to keep up?
          2 GB RAM
          250 GB hdd
          500 GB USB hdd
          M2-ATX
          D-Link DWL-121 WiFi
            ^ isn't that possible through OBD2?
              You can monitor the voltage that your OBD2 port sees via an ELM command (I forget it, look it up on google), however if you have a USB ELM devices chances are the voltage command will always return 12v regardless because the elm in most usb devices is powered off an internal regulator.
              You could get a fusion brain, but it only accepts 0-5v input and it's not protected in any way so I wouldn't suggest hooking up your car's voltage to it without some supporting circuitry. If you get that protection that could do it. You could even work in an amp-meter
              RevFE
              My Shop
                Stock alternators are not rated for continuous duty. In other words a stock type 140 amp alternator can only output full power for a short period of time. this is how they are designed and. that is a maximum rating at a certain rpm etc. If you are pulling a lot of power from the battery to the point where the alternator is having to work hard for long periods of time. then can overheat. they can also go into saturation where they simply go wide open and the voltage go up to 16volts. then they cook the battery and you start an endless cycle of replacing batteries and alternators. stock alternators just weren't designed with big big car stereo systems, where you have a large constant current draw, in mind. they were designed for the short large current draws like from a starter motor and a smaller constant current draw over time.
                Heavy duty purpose built alternators are a different story. I have seen specialty alternators built for the car stereo market that will output full power all day, again as long as it is held at a certain RPM.
                The Optima batteries while cool, and can be mounted in any position etc. have one major downfall not many people understand. They typically have a lower A/Hr rating per a given size then a conventional lead acid type battery. What this means is. that with a given fixed load, the optima battery will die faster. everyone talks about CCA, cold cranking amps, but that spec is meaningless when it comes to car stereo's. CCA is simply the measure by which how many amps maximum can be drawn from the battery for a very short period of time at 0 degrees. The A/hr rating which is often not published is the amount of current that can be drawn from the battery per hour for a given period of time.
                there is just no substitute for size. Great big die hards have a very long A/hr rating. and in a car audio system will last much longer and your alternator will not have to work quite as hard. as the alternator can recharge the battery at a lower rate over a longer period of time. where as optima batteries of any color have a very short A/hr rating for the same group size. this means your alternator has to work harder to keep that battery charged! adding another optima would give you a longer A/hr rating and again your alternator would have an easier job.
                as long as you dont run the batteries all the way down. IE less then 11 volts. in which case a proper wall type battery charger can bring the battery up to a level where the car's alternator can handle it without burning up.
                  OK, so are you saying I'd be better off w/ a larger Die Hard than the Yellow Top if I'm using a stock alternator?
                  2 GB RAM
                  250 GB hdd
                  500 GB USB hdd
                  M2-ATX
                  D-Link DWL-121 WiFi
                    no, he is saying that for a large stereo, a large diehard sealed battery and a high output alternator would be best.
                    next project? subaru brz
                    carpc undecided
                      Optimas Ah is pretty high and usually only slightly smaller than other comparable batts. Thats because the batt consists of 6 cylinders instead of a rectangle so its actually smaller in size which is why its Ah is slightly smaller.
                      And they are much higher than most conventional batts. I think you mean to compare them to other sealed AGM batts.
                        i was told once that the cylinders and gel medium are what makes the Ah lower because it can't make the chemical reaction fast enough--same overall info though (optimas are worse than standard batteries for high, constant, draw), but i might have been misinformed..
                        carpc undecided
