1600 watt amp install - need help with power issues
  • 1600 watt amp install - need help with power issues
    I just installed a Phoenix Gold Ryval V8001 1600 Watt Monoblock Amplifier using an amp install kit rated at 1500 watts (4 guage power and ground wire) and hooked that up in parallel to two 4 ohm Pioneer Premier series 1000 watt subs in a band pass box and am noticing considerable headlight dimming and power drain and need some help figuring out how to fix this issue.
    I've done some research and found that testing the battery and alternator would be a good first step, and I'll do that later today.
    As well, some suggest installing a 1.5 farad cap, but others say that this cap will not provide the continuous power needed by the amp. Some say to install an extra battery solely for the amplifier. Others say to install a battery AND a cap. With all the differing opinions out there I'm not sure what I should do
    I have a stock 90 amp alternator now, and will be replacing that with a 120 amp alternator later this week. I have never had any power drain issues prior to installing the amp so I believe my car is simply too underpowered at the moment to cope with normal power drains AND the added drain of a 1600 watt amp.
    Would an extra battery alone solve my issue? What kind of battery should I get? How would I hook it up?
    Would a capacitor also be needed in conjunction with the battery or would a cap alone solve my issue? Should I go with a cap cell instead of a single cap? If so, what type/brand?
    Thanks for the help
    1 - Update your grounds with more capabile wiring (thicker = lower AWG).
    2 - Upgrade your battery to a deep-cycle unit and/or one with more amperage output.
    3 - Upgrade your alternator to one with more amperage output (you already specified that).
    It's called "the big three". Google it.
    How about the Wiki?
      4 - don't waste money on a cap.
        I just read a very in-depth article explaining the Big 3 at this link: http://forum.sounddomain.com/ubbthre...e/1#Post312025
        I'm going to do this and hopefully solve my power drain issues. After that, if I still have significant power drain, I may do a 2 farad capacitor.
        Thanks for the advice.
          the biggest problem with caps is that they tend to hurt only a little less then they help-- its like a glass of water connected to a pipeline through thin tubes-- sure it keeps a reserve for when you need it, but once you use any of it, it takes a while for it to fill back up, and while filling up, draws that water away from the other things that need it (your amps)..
          next project? subaru brz
          carpc undecided
            I've said it on before and will say it again, a cap will do nothing beneficial for your system. They are a gimmick designed to lighten your wallet. Ask any SPL guy and they will all likely have one or more for sale, the ones that they removed back when they first started out, knew nothing, and bought into the hype before learning any better.
            Data911 M5 system
            RR and iGo8PC
            Pioneer head unit
            Pioneer DEQ-9200 digital processor
            Phoenix gold line drivers
            Ultimate and Visonik amplifiers
            SMT 3 way active front stage
            Digital Design sub woofers
            3 runs of 0 gauge wire
              Caps are purely a cheap bandaid to help smooth bad power until you fix the underlying issue. It will not help give more "power" to your system, though it might help sound quality due to dirty power causing your amps to freak out, but this is an issue which should be fixed regardless.
              Capacitors do NOT provide power. They smooth out AC ripple in a DC line. If you were to power your amp only off your capacitor, it would probably run for all of about 1/10th of a second if that. This is how much power "storage" a capacitor has. (purely an example, depending on amp and cap size your time may vary). So unless you're only pulling power for 1/10th of a second, that cap isn't gonna help lighten the load on anything.
              RevFE
              My Shop
                +1
                you said that the original issue is that all of your lights dim when you start turning it up. instead of imidiately throwing more money at it, try to determine [U]why[u/] the lights are dimming and fix the problem(it could be the big 3, but it could be something else too). while it is the harder way of doing things, it will prove to allow you to make a more reliable and stable power circuit in your car and you will have alot less problems down the road. remember-- that same voltage/current that is causing the dim lights also powers your engine computers-- and if the voltage goes too low, too much, it increases the chance of that going out(computer would see it as something like a constant brown out)-- and those aint cheap for any car.
                carpc undecided
                  I've always wanted to do the math, and here's my chance.
                  Let's assume a standard 1 Farad capacitor and this guy's 1600W amplifier.
                  1F = As/V (1 Amp second per volt)
                  P = EI (power = voltage * current) Solve for current, we have I = P/E
                  Substituting we have:
                  1F = (P * s) / E^2
                  Solve for seconds:
                  (1F * E^2) / P = s
                  Plug in values:
                  (1 * 12^2) / 1600 = 0.09 seconds.
                  Wow, pretty close there, Malcolm.
                  Oh, wait, he's looking at a 1.5F cap. 0.135 seconds, then.
                  (Note: capacitors don't have a constant voltage/current as they discharge so the amp would likely get a usable supply for significantly less time than this)
                  That being said, going back to I = P/E
                  1600 / 12 = 133 Amps. Off a 90 Amp alternator. Uh-huh.
                  (Note: if 1600W is the RMS supply to the speakers at max output, then the drain on the electrical system is actually much worse as the amp is not 100% efficient)
                  It bears repeating: capacitors and batteries are only temporary storage. To power those loads on a consistent basis you need an adequate power supply and that means a properly spec'ed alternator.
                    get an alternator that can supply the power you need.
                    will a 120A be enough? basic math....
                    1600W amp@ 13V will ask for 115A in itself, dosnt leave alot left for anything else
                      it also need to be said that higher power alternators will need to be reved higher to maintain the amperage listed on them-- don't expect to get 120 amps it at idle...
                      carpc undecided
                        That amp only pulls around 70amps max. Also music is dynamic so that load will never be consistantly maxed out.
                        A bigger alt is overkill for this system imho. I've seen plenty of installs with much more power on stock alts without bad dimming.
                        I would
                        1. do the 'big 3'.
                        2. run a seperate ground cable to your amp (alot of dimming probs come from bad grounds)
                        3. get a good batt to replace your stock.
                        If you still get bad dimming, then
                        4. get a second batt for your trunk.
                        Note: You can upgrade your batt without upgrading your alt. But you would be foolish to upgrade your alt without also upgrading your batt. Keep that in mind.
                          I wouldn't put batts and caps in the same category. A batt is a rechargeable power supply. Theres a big difference.
                            I think Deka batts are the best value for the price. Otherwise Kinetik is popular right now but I think they are overpriced.
                              I would put them in the same category. They differ only in their capacity.
                              If the current drain for your accessory load is greater than what your alternator can supply then the deficit has to come from somewhere and that means your battery. If your battery is supplying power, it isn't recharging and will eventually discharge. You have to ensure that you periodically reduce your load so that the batteries have a chance to recharge.
                              I will, however, agree on the "Big 3" and the ground for the amp. Those have the possibility for increasing the load on the system and pushing you over the edge.
                              Also, checking into the specs for that amp, it's only 800W RMS into 2ohms so ~67amps at 12v (less at alternator voltage) so double my numbers for time calculations above.
