AMP troubles
  • AMP troubles
    I have a B2.300.4 lightning audio amp, and a 12inch jenson pro sub, i hooked the power wire to the posative on my battery, the ground is fine and the remote wire is hooked to the ignition so it turns on the amp when i turn the car on, but since i hooked it up all i get is the protect light, i unhooked the RCA cables that run from my stereo to the amp and the light goes off but as soon as i plug them back into the amp the light comes back on........what can i do?
    Unplug the sub, then plug in the RCA's and let us know if it still goes into protect.
      also, check your rcas for a pinch/short.
      next project? subaru brz
      carpc undecided
