How would this amp measure up?
  • How would this amp measure up?
    Boss CX350
    Product Features
    Single 4-channel power amplifier
    Sensitivity: 90 dB
    Power output: 50w x 4 RMS, 100w x 4 Max
    Line and speaker level inputs
    MOSFET power supply
    Technical Details
    Power handling: 50w x 4 RMS, 100w x 4 Max
    Sensitivity: 90 dB
    Inputs: Line and speaker level inputs
    Trimode operation: Yes
    Bridgeable: No
    Remote subwoofer level control: Yes
    Bass boost: 0-+18dB variable bass boost
    Variable gain control: Yes
    Indicators: Power and protection LEDs
    Crossover: Variable lowpass and high pass crossover
    Power supply: MOSFET
    Dimensions: 7.5 x 9.8 x 2.2 inches
    Weight: 3.6 lbs
    My VW Jetta Worklog
    Personally I wouldn't bother with Boss. They are the bottom of the line for amps.
      I'll second that, they should have just stuck with headphones.
      Data911 M5 system
      RR and iGo8PC
      Pioneer head unit
      Pioneer DEQ-9200 digital processor
      Phoenix gold line drivers
      Ultimate and Visonik amplifiers
      SMT 3 way active front stage
      Digital Design sub woofers
      3 runs of 0 gauge wire
        i also agree with them, though if you are on a tight budget, and really can't afford a name brand amp, it will work fine, and will amplify sound. but there are better(also, more expensive), name brand amps out there that will will do it better, but are more reliable.
        next project? subaru brz
        carpc undecided
          I AM on a budget and just pushing stock speakers in my '05 VW Jetta. I want/need something under $50.00. Anything better for the price? Would this sound as good/better than the stock HU? Thanks for the info!
          My VW Jetta Worklog
            Oh, and one other thing since I am a COMPLETE noob when it comes to car audio; since the front speakers are split into separate tweeter, mid and woofer...do I need any special considerations when looking for/hooking up an amp to them? Or do they all get twisted together and put on one channel?
            Thanks again!
            Bill
            My VW Jetta Worklog
              If you just want it to sound like a HU, you can get any amp really.
              1.9in x 2.9in -- 47mm x 73mm
                Thanks again!
                Bill
                There are a lot of unknowns there.
                Chances are there is a crossover for those front speakers. There is one signal line that goes to the crossover and that sends the highs to the tweeters and the rest of the audio to the midrange. In that case, you simply run your front channels to the crossover and you are good to go.
                Mind you what I described is the most common setup, and may not be how your speakers are wired.
                Since you know you aren't knowledgeable about car audio, it's time to learn. I suggest taking your car to someone who is, be it a car audio shop (who will probably charge you), a friend, or someone at a car or car audio show. Have them look at your front speakers and determine what you need.
                How about the Wiki?
                  FYI, I ended up going with this one after doing way too much/not nearly enough research. There is a LOT to know about amps!!! $50.00 used on craigslist.
                  •70 watts RMS x 4 at 4 ohms
                  •140 watts RMS x 4 at 2 ohms
                  •280 watts RMS x 2 bridged output at 4 ohms
                  •2-, 3-, or 4-channel output
                  •4-ohm stable in bridged mode
                  •Tri-way capable (Tri-Way crossover required)
                  •requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
                  •PWM MOSFET switching power supply
                  •variable 50-200 Hz high-pass/low-pass crossovers (12 dB/octave high-pass, 24 dB/octave low-pass)
                  •ThunderEQ bass boost (up to 18 dB at 40 Hz)
                  •preamp outputs
                  •13-15/16"W x 2-1/8"H x 9-3/4"D
                  My VW Jetta Worklog
