any phase plugin
  • any phase plugin
    is there any phase plugin wich control the phase....ike in 360 degrees...exept of voxengo pha. 979...
    or how can set the plugin pha979 to play go sound!
    i intalled it and there where strange sounds with it.
    Carputer to sell : http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2684
    why do you need to control the phase?
    playing with the phase on mids or tweets can lead to a very interesting soundstage
    next project? subaru brz
    carpc undecided
      i edited the first post..maybe it wasnt clear
        you could also use a time delay plug in--- both will do the same thing, but have different measurements to how they do it.
        carpc undecided
          i have a sound delay plugin, and i want a phaze plugin....to get the most sq possible of my system.
          do you have any good phase plugin?
            Hey,
            i'm using a vst called phasebug and it's working very good..
            i can also recommend using ARC ROOM CORRECTION for virtually setting up the front stage (don't use it with the subwoofer coz it will virtually disable it due to the vibrations in the car) all together like a pro !! - all you need is a measurement microphone such as behringer ECM8000 - a samll price to pay for auto calibrating your home and car sound stage..
            Have fun..
              thanks
