Kenwood aux input
  • Kenwood aux input
    Hi ppl
    I have an Kenwood gkr-6500rlm and i have bought this cable http://www.tme.eu/katalog_pics/3/c/b...ux_kenwood.jpg and connected it, but in radio i cant get the src to aux. When i press the button src the radio only changes between off and tunner.
    Someone can help me ?
    If anyone have the manual i would apreciate
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    http://www.diymobileaudio.com
    http://www.soundsolutionsaudio.com
    http://www.dynamicautoacoustics.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    How about the Wiki?
      The link to the picture doesn't work for me. But on my Kenwood you have to go into the menu and enable the AUX input or it doesn't show up as an option when pressing SRC. It's probably the same on your deck. See if you can download the manual from Kenwood's site, they have most of them online.
      Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
        I have solved the problem
        The cable that i buyed dont work because my mode have a different pinout
        (you can see the pinout in this link: http://www.mictronics.de/?page=cdc_proto)
        Some kenwoods is only connect pin 1 with pin9 with a 10k resistor, in another models we have to connect pin3 to pin9. After put the resistor de radio has the option disk (pressing src button) but when i plug the cable the disk option dont appear. I discovered that the problem is that the cable is making connection between pins 3 and 9, so, after cutted pin 9 from the cable its working fine.
        I hop that this post help someone with the same problem :P
