something makes my tweeter clipping ...and a little my midrange...
  • something makes my tweeter clipping ...and a little my midrange...
    HI....i got something making my tweeters cliping ...
    i do not really hear them...and when i put the sound up the clip....
    the problem appears with my midrange too...but less...
    i played with my gain...but thats not the problem...
    So i would like to know if is there a signal wich can do clipping in my speaker...(in the carputer)
    is there any level that i could lower in the pc? there are many level ajustment everywhere
    my setup:
    asus xonar 2d pci sound card...
    audiomulch
    lsfilter
    could it be my soud card wich has just 2 volt rms of outpout?
    wich makes my speaker cliping?
    Carputer to sell : http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2684
    if you dont understand i could try to explain more...
      maybe wungun you had a similar problem like that?
      should i just change the sound card?
      what can i do?
        or maybe it is the asiofor all.?
        is there a way to replace it?
          i am realluy starting to think it is the vac or the asiofor all....is there anyways to get sound without these?
            Sounds like a crossover problem.
            PROGRESS:
              it could also be your cable from the sound card to your amp...had a problem similar to yours once, and that was the issue...my midrange on driverside was out completely, replaced the cable, no more issue.
              Trouble deciding on car speakers? Clicky Clicky
              Speakers: DLS Ultimate Iridium 6.3 Link
              Subwoofer: removed
              Amplifier#1 (Front Stage): DLS Ultimate A4
              Amplifier#2 (Sub) removed
              Carputer: Removed for tablet install
                i pluged the pc into my hosue....and i plug a headphone in the tweeter jack....
                it made the same thing...
                i try to put my xonar audio card into my other home pc...and the card was playing perfect....
                in my other pc i have windows vista...maybe it is taht....i know that wungun has two sound card with windows xp...but maybe he do not use this outpout(high)
                  maybe a driver isssus with xp...
                  or the carputer motherboard is not compatible with my sound card
                    http://www.mp3car.com/vbulletin/powe...ing-my-pc.html
                    go to see this topic...i almost found the problem...
                      the problem disappeared completly by changing the psu for an opus 360 w!
                        You can't use a M2 or M4 with PCI sound cards...they are junk.
                        I couldn't even get any sound at ALL with 2 soundcards.
                        Glad to hear you got things figured out!
                          i will know next time....
                          note to myself...do not by cheap things...
