Someone please help with audio!
  • Someone please help with audio!
    Just installed a car pc in my 2003 tib gt. i have the infinity sound system. I have an external sound card that has 3 sound outputs for front, rear and sub. I have the adapters to run from the card's stereo output to rca to speaker wire all hooked up and the sound works, i checked it with other speakers. My problem is i followed the wiring diagram from behind the stock stereo. The only way i get sound to all my car speakers is to run ONLY the positive speaker wires to the corresponding wire in the harness. I always thought you needed both pos and neg but when I hook up the neg wires it cuts out the sound immediately. Also, while I have the pos wires hooked up i get extra noise in my speakers. If someone can help me hook this up I will pay you. I would rather pay someone on here that may have experience rather than in my hometown audio store possibly not knowing what they are doing because it is a small shop. If no one can help me than can someone please let me know of a place around the chicago area that will definitely do the job without any problems. I'm tearing my hair out, I've had the pc half assed installed for about 4 months now and finally finished molding my screen into my center fascia. Looks awesome by the way. I'll post pics when I'm completely done. Any help would be greatly appreciated.
    Here is a little more detail-- The card has 3 outputs. One for front speakers,one for rears and one for subwoofer. They are all stereo out puts that have been converted to bare speaker wire at the ends. So at the end of each output there is bare speaker wire for left and right speakers. This is what I am hooking up to my stock stereo harness. I have the stock infinity amp but there are no rca's or anything, just the wiring harness that goes into that also.
    Electronic Space Foot
    so, basically, the stock radio sends out regular speaker wires to the amp (meaning its a high-voltage input on the amp, not a line-level)? if this is the case, the problem is the output from your soundcard is PREamp level, not high drive like your stock radio is sending to the amp.
    also, those outputs you have for front, rear and sub are stereo like you said- meaning there is 3 points of continuity for each one, not 2. it should be left+, right+, and grnd for each output.
      Yeah there are 3 point of continuity for each one, yet when i hook up the neg part of the wire the sound cuts out.Also, if what youare saying is true about the output on the card being pre-amp then what should i do? I have been tearing my hair out trying to figure this out. Thank you for your help.
        well youre all over the place right now, you gotta start somehwere and stay on one path.
        so, first, does the amplifier itself have rca jacks on it for input? if so, just use proper adapters to go straight from the computer to the amp.
          This may not be relevant, but did you connect the amp remote turn-on wire, pin 12 on the harness behind the radio in the dash, to a switched +12V source?
            the amp does not have rca jacks. yeah i have the amp remote wire hooked to the amp. i didnt have sound at all until i did that. like i said, this is really weird, when i hook just the positives wires up i get sound out of my speakers, but as soon as i touch the negative wires to their respectives places it cuts the sound out. i have no idea why it would do that.
              the positives normally do work a little when you just have those hooked, because its using the ground inside the amp to backfeed what its missing. its not a good thing though, dont leave it like that.
              you still need to find out if the wires coming out of your radio, that go to your amplifier, are high or low voltage. high would mean you can just hook up a speaker and it would work- those wires are amplified. low would mean they are just signal wires, and you could put headphones on them if you wanted to (which is the reason you have headphone jacks on your computer, they are low voltage lines and are not made to hook up to speakers, unless you get the kind of speakers that you need to plug into the wall for power).
              my guess is the amplifier uses high-side inputs only, and you are trying to feed it the low-side the computer provides. if thats the case, you could probably modify a basic set of pc speakers to go into the amp, but then youre adding a lot of extra crap. you really need an amp or radio with low-side inputs, there isnt much around it.
              also, you dont by chance have an mp3 player input on your stock infinity radio system do you?
                Ok, so could i just buy another amp and replace my stock infinity amp with that then? I don't mind spending more money on something that's going to work!
                  honestly if you could upgrade your radio i think that would be a better route. you would get better sound then your factory radio, and the amplifier you have is matched to your speakers so its nice to just leave that alone. even a $140 pioneer cd headunit would sound excellent, you dont have to go crazy there as your pc really provides the sound. the new radio will be just that, am/fm cd radio with rca inputs. just get a good name brand and you should be fine.
                    yeah would do that but I'm not going to have a deck at all, sorry i didnt mention that.where my radio goes i molded my touchscrren lilliput into the old center fascia.
                      ok, thats not my idea of ideal but whatever you want is good. you will need a new amp it sounds like... there are other ways to hack what you have into working, but it wont sound as good as it should.
                      do you know what size amp you have? how many watts? we could help you pick a decent one for a good price im sure.
                        I'll have to check that out tomorrow when its light out. It's just my 2003 tiburon's stock infinity amp. Just curious, but why wouldn't that sound as good? Hmm, I've seen other tiburons with the ash tray and cig lighter removed and they have a deck in place of that. Maybe that would be better. Then, I would still have my screen and have a deck below it. Ill try and find a pic for ya, hang on a sec.
                          My mouse just took a crap on me gotta go find a new one
                            like this-
                              no, i mean if you want to get crazy technical, supposedly having the least amount of devices in the audio chain leads to the best sound... but a good head unit wont change a thing. what i like about having one is the physical volume knob and control that it totally seperate from what windows is doing. it never fails and is always instantaneous across the board of anything youre doing. also, its really nice to have the am/fm radio that, 1) works better then anything you can add to your pc and 2) works even when your pc isnt. you also get a shock-proof cd player with a headunit, which doesnt matter much because its just for cd's, but those too of course work when the computer is down too.
                              either way isnt a big deal though, it seems about 50/50 on the people that like it and those who rather just feed straight into an amp and rely completely on the pc to do everything.
                              another really nice thing too is the speed control volume... you can let RR go from 60% at 0mph to 100% when you hit 55mph or whatever, and since the headunit controls the final volume, the speed controlled volume from windows just becomes a varying attenuator. it makes things very automatic, because its always on and just raises the volume enough to compensate for road noise no matter how loud you have the volume on the headunit.
