CAR AMP Harness to RCA connectors?
  • CAR AMP Harness to RCA connectors?
    hi, I need to know if this works. From an old thread someone used a Metra 70-1725 connect to the AMP and get input from the soundcard. Can anyone please confirm. thanks
    are you trying to run the stock HU wit the carputer? if not go get a metra kit that will plug into your bose amp under the passenger seat that will convert it into rca's, then plug those rca's into the sound card of your computer. easy as that. i have an rsx too and currently working on carputer. let me know how you do.
    Old Thread:
    http://www.mp3car.com/vbulletin/gene...-you-pros.html
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    yes, that will work. it is very similar to the harness that i used in my eclipse-- you basically just need to attach the rcas to the sound card outputs, and connect the amp remote turn on wire to a switched source.
    next project? subaru brz
    carpc undecided
      thanks
