PC Optical Out to Analog In Amp - DAC or DSP?
  • PC Optical Out to Analog In Amp - DAC or DSP?
    Hello,
    I have been doing some searching and I believe I need a DSP but would appreciate a second opinion.
    I am upgrading my car pc to http://www.zotacusa.com/specsheet/ZO...TX_US_v3.1.pdf which has an onboard optical output but my amp has analog inputs. I was hoping to upgrade my amp to all digital later on (once funds were available), but until then, I was hoping I could wire the PCs optical port to the analog inputs on the amp.
    Any recommendations?
    Thanks and Regards,
    --Tim
    you would need a d/a convertor:
    http://www.ramelectronics.net/audio-...dGEF00232.html
    and at $68 each, not a very cheap option...
    from what i have read in the past on toslink outputs-- not sure if it applies to this one or not, but sometimes the toslink output will only work in certain modes-- some don't output stereo, others don't output surround...
    also, that board does have analog audio outputs(their near the wifi antenna), so don't feel locked into only using the toslink output.
    next project? subaru brz
    carpc undecided
