Installing amp with sub.
  • Installing amp with sub.
    Hello, I have Alpine MRP-M500 (500W RMS and 1000W max) amp with SWR-1222D Type R sub (2 ohm, 500W RMS and 1500W peak). I was looking at a 4 gauge amp kit with a 150A fuse.
    1. Will the amplifier be alright with the sub woofer? Is it too much or too little power under powering the sub?
    2. Is the 4 gauge wiring too thick? And will my battery support it.
    1. yes
    2. 4 ga is perfect i would used 0ga if i were u
    2a. you can buy battery clamps to replace stock ones
    2005 Pontiac G6
    Headunit: AVH-P3100DVD
    Front speakers:Infinity 6022i
    Rear speakers: Powerbass pb-b6.5xv.2
    Battery: top of line walmart brand(LOL)
    Wiring: 1 run of 0 ga
    Amp: MTX JH600 & Lightning Audio B300.4
    Sub: TS-W2000SPL
      It looks like the amp and the sub are paired up good.
      I would be more comfortable running 2 or 1/0 ga wire.
      You will need to check the age of the battery, the output of your alternator, and will need to make sure that you have a good solid ground
      next project? subaru brz
      carpc undecided
        That set up looks good
        You cant have too thick of wires for that
        Your battery can support it. Its a question of weather your alternator can or not. But it should be able to handle it no problem
        your going to need to buy a smaller fuse. 150A isnt going to protect much for that set up
        '93 Toyota Celica - First Car PC install
        Current System Specs:
        ZOTAC GF8200-C-E AM2+ GF8200
        AMD Athlon 64 X2 3800+
        1 GB DDR2 667
        LITE-ON DL-8ATS Slot-Load
        750 GB Seagate SATA HDD
        250W PSU
        19" Hyundai Monitor
          As already stated above its all good, but again I would go larger than a single 4 gauge wire. Always run larger than you need to allow for future upgrades, that way you won't be kicking yourself in the gonads later on when you have to do it all over again. Run a 0 gauge wire and be done with it.
          Data911 M5 system
          RR and iGo8PC
          Pioneer head unit
          Pioneer DEQ-9200 digital processor
          Phoenix gold line drivers
          Ultimate and Visonik amplifiers
          SMT 3 way active front stage
          Digital Design sub woofers
          3 runs of 0 gauge wire
