Need Some Help With Pioneer AVH P5700 DVD?
  • Need Some Help With Pioneer AVH P5700 DVD?
    Hi Guys,
    I've Pioneer AVH-P5700 DVD & I've connected my mobile to the DVD player through its TV-in Socket in the DVD as my mobile ( Nokia N95 ) Got TV-Out. But I faced a problem which is I do not know where to connect the Audio Cables!! there is only 1 TV-in socket and there is no Audio-in socket !! I use this cable ( http://images.channeladvisor.com/Sel...M-CAB014_a.JPG ) and I used only the yellow one for video.
    So how could I connect the Audio Cables ? should I get an amplifier ?
    There should be some audio inputs right near to the video input on the back of the unit- I believe that your paticular unit should have 2 auxilary inputs, so make sure that you use the correct one
    and just FYI: this section is dedicated to installing and integrating computers with car audio systems, so any audio specific questions you have might take a while to get answer. There is a list of car audio specific forums at the top of the page.
    Feel free to stick around, and maybe convince yourself to install a carputer though
    next project? subaru brz
    carpc undecided
      I do have an auxiliary input , but to use it I should use the AUX source & not the AV-Source.
      And I am already convinced by installing a carputer, I got the screen of my Pioneer AVH P5700 DVD player & as I told you before I could not connect the Audio cables ?
      And about the computer, Now I am still thinking of making a laptop as a carputer or a mini desktop as a carputer, and the biggest problem is I do not know from where to start , I am still searching the forum for the way to start this project, its my first time to do so.
        Any DVD unit like that is a poor choice for a carputer screen- becuase it only accepts composite inputs, it is too low of a resolution to properly display computer video- so text on the screen will be harder to read
        the av input on the back should have all the cables you need- they should be RCA cable connections, being that I can't find a pic of the back of the unit/connections, could you take a pic of the back of your unit?
        carpc undecided
