Carpc to OEM amp
  • Carpc to OEM amp
    Hi all,
    I would like to have a carputer directly connect to the OEM Amp (which is a Bose 3512 amplifier), which does not have any standard RCA input. Any idea on how i can hook up the carpc directly to the amp?
    You can either purchase or fabricate a wiring harness for the factory amp.
    You'll have to do some looking to find what you need.
    You can also ask at a car audio shop, but expect to pay more.
    How about the Wiki?
      some factory amps require line level, others require speaker level--
      line level would be the signal that comes out of the pc-- if it accepts this, then you would just need to hoock it up correctly.
      speaker level is the higher voltage signal that comes out of a amp-- if it uses a input like this, than you would need a small amp to boost the signal before sending it to the factory amp. a few members have had good luck using motorcycle amps off ebay.
      next project? subaru brz
      carpc undecided
        If you're good with electronics and soldering you can convert speaker lever input to line level. I did this with the factory amp in my Jeep. At the time I installed my carpc I didn't want to start the audio side of the project so I just modified that amp until I'm ready to deal with the full audio phase of the project.
          I used a PAC-Audio device to connect my car computer to my factory amp; nice and clean and no need to alter the factory wiring. http://www.pac-audio.com
            Thanks for all you guys advise. I have just tailored a cable by myself to connect my computer to the OEM bose amp, and everything works fine. I am trying to connect my OEM blaupunkt back to the carputer (coz i want to use my carputer to listen mp3 without switch on the HU, so lazy ), unfortunately there is a ground loop. Anyway, tailor a cable works fine....
