Sound Card.. is this possible
  • Sound Card.. is this possible
    ok so i needed a sound card that had decent preout levels. i chose the audigy zs2 pci soundcard. well ive been doing to researching and something i missed before is securing th card into the slot. im wondering if there is a way to use the pci card through usb? some sort of converter? ive been looking everywhere and all i can find are pci to usb port adapters. any help?
    CarPc Progress
    Planning 100%
    Assembly & Fabwork 80%
    Installation 95%
    Bugs worked out 45%
    Sorry, but I don't think such a device/external enclosure is made nor do I believe that it is possible to make due to the connectivity requirements the pci bus has with the typical desktop motherboard.
    does your laptop have a pcimcia or express card? If so you can use a similar soundcard that utilizes that slot, If not you can get a usb to pcimcia/expresscard adapter. And there is always the external usb soundcards.
    The best way I've personally found for reliability is optical or digital spdif to an external sound processor, they typically have more than adequate preamp levels. And this method reduces or eliminates any noise from the computer using typical analog means (RCAs to car amplifiers). It may prove more expensive, but it has provided more than adequate results for me.
    PROGRESS:
      when comparing computer sound cards to aftermarket head units, the head unit has always had a better output voltage-- so far, i have not seen any sound cards that have enough voltage to drive a amp as good as a head unit.
      i would recommend a couple of preamps [insert jl audio cl-rlc plug here/] if you don't want to spend $900 on a audio proccessor.
      next project? subaru brz
      carpc undecided
        yeah i know that the soundcard preout isnt strong enough. i have a phoenix gold line driver which is essentially produced by audio control. i needed a card that put out around 1-2 volts and the line driver will take it from there to the amps. my biggest choice in that card was that i need 3 line outs (2 front, 2 rear, 2 sub) and also a line in for my directed hd radio while maintaining the 1-2 volt requirement
        i have the desktop version of the card not the laptop audigy 2zs (i misspelled it the first time)
        ive just heard so much about usb soundcards slowing down boot times as well as issues from resume. reliability and consistency is key for me.
        CarPc Progress
        Planning 100%
        Installation 95%
        Bugs worked out 45%
          This probably won't give you much hope...and it's subjective too...but...
          I've used both a USB Audigy and a USB X-Fi and thought that the onboard sound was better. They did slow down boot times, and I'm assuming the poorer sound quality was due to the low output voltage on the USB units.
          I've since switched to a PCI-E Asus Xonar DX and the sound is so much more alive than ever.
          JL-Audio amps driving Infinity speakers.
            you might be talking about the creative x-fi usb card and intel boards-- i used one for a little while, and it took about 20-30 seconds longer to initialize before booting. my newest card, a esi gigaport hd(still a usb card) doesn't even add a noticeable amount to my boot time...
            it seems it is primarily a issue with creatives drivers, and intel boards, though no one has been able to figure it out past that...
            i dont really understand why you need a 1-2v line bfore the preamp-- that is what they are designed to do-- my cl-rlc's do a great job of upping the signal from the low level of the gigaport hd..
            carpc undecided
              im assuimg based on ur question... u have limited space in your pc case?
              in regards to having the pci card standing upright..
              could any one these help your in ur issue?
              more specifically this one?
              if i am wrong about what ur intention is, i aplogize
              trinybwoy
              2006 Mazda6 Carpc
              2008 Acura TSX Nexus 7
                maybe subjective but opinions are always helpful since you never know what they will uncover. thanks
                saving space is never a bad thing lol. ive custom fabbed version 1 of my case. version 2 is in the planning stages to fix the problems with v1. one of the being overall size. v1 is 9 x 9 x 9 i believe. i looked at the risers and riser cables but was really concerned about a card hovering right about the processor fan. it seems like that would block airflow which is not a good thing. if im worried about nothing please let me know and ill probably do the riser.
                i just looked at the esi gigaport hd...does that have a line in? well the 1-2v was just so it didnt have to amplify a really low signal (like adding boost to a built engine vs a stock engine sure they both will work but quality..just a concern thought id play it safe)
                also im custom building a center console so ventalation is starting to be a concern with the pci card not taking up a full wall of the case that allows for more airflow. weighing options trying to get everything done right. i really appreciate you guys' responses
                CarPc Progress
                Planning 100%
                Installation 95%
                Bugs worked out 45%
                  sorry, no line in on the gigaport-- my aux line goes straight to my amps--i am running 2 inputs to my amps-- aux, and carputer. this is so that when i fix the computer, i can drive the car and not go crazy...
                  for the pci risers--they seem to work when they are brand new, and plugged in all the way, but you would need to secure them very well-- after a 2-4 years, they start having flakey connections for no reason. also, i have issues running network cards on them, and then swapping back to a different pci device-- for some reason they don't work after that except for the network card.
                  carpc undecided
                    no airflow issues with it sitting right about the heatsink fan? huge worry is overheating. if i can use the riser i would do an in dash all in one setup as long as i can get everything to fit. the only thing i would use the riser for is the sound card. no other use for it. how would you suggest securing it down.
                    CarPc Progress
                    Planning 100%
                    Installation 95%
                    Bugs worked out 45%
                      you can use some simple aluminum or steel bars to make a bracket to fit and hold it. Most if not all the pci/pci-e risers I've seen and used have 2 mounting holes used to secure them in place. You can get small steel or aluminum pieces you can cut and use from places like Lowes or Home Depot for fairly cheap.
                      Or you can use gobs of hot-glue or liquid nails
                        the risers that i used kicked the pc card away from the cpu fan, so there was no issues with heat...
                        but you should be fine as long as you give at least a 1/2" of room above the fan for circulation.
                        carpc undecided
